AF: Battle of Tailgates - RAM strikes again | Page 4 | Allpar Forums
Discussion in 'Mopar / FCA News' started by Fast Eddie, Sep 12, 2020.
  1. sickboy
    sickboy Well-Known Member
    Feb 28, 2011
    941
    919
    I was very excited about that. I can imagine that
    A: it may have compromised bed space. Although I believe ram boxes do that already
    B: any damage or dents To the bed could render it useless
    C: if the ramps are bent while extended, they may be unable to be retracted. A huge problem if they were fixed to the bed.
    but if uhaul can do it, ram should too
    tabutler and XRT2SRT like this.
  2. XRT2SRT
    XRT2SRT Well-Known Member
    Aug 25, 2011
    1,041
    453
    Speak of "crank windows", I recently rented a Uhaul that upon leaving (less than 1 mile) the lot, I discovered said crank window's handle just spun on the input shaft...lol! :eek:Then the low-fuel indicator dinged....:( So, after two brief conversations, I was ordered to return it to the lot and pickup correct vehicle (sales person goofed) . Surprisingly, I was okay with the crank being inoperable but, the low fuel start was a deal breaker; the newer truck was much nicer! ;)
  3. XRT2SRT
    Aug 25, 2011
    1,041
    453
    Just a thought here...are RAM BOXES available as an add on item, if one wishes to fork over the cash out of pocket??
  4. XRT2SRT
    Aug 25, 2011
    1,041
    453
    I choose "C" as my answer.
    UN4GTBL and sickboy like this.
  5. XRT2SRT
    Aug 25, 2011
    1,041
    453
    The tailgate on GMC SIERRA is a masterful design until someone get overly aggressive on the go pedal in reverse and crumples that cute thing like so many have been prone to doing. And though I this can be true for either make, I think there are just too many parts to fail there. K.I.S.S. RAM WINS!
    Tony K and tlc like this.
  6. Adventurer55
    Adventurer55 Well-Known Member
    Nov 9, 2015
    3,413
    4,437
    All of these ideas are good on paper, but what a few years on the salt filled roads of the north? Truck companies haven't made frames that won't rust in two yet, so what about these sheet metal appliances?
    wvutuba and kevin m. Henry like this.
  7. Tony K
    Tony K Active Member
    Jan 11, 2019
    924
    1,321
    Farmers mostly are now. That bridge is already burned. What we need now is the true half-ton Dakota with the 5000 lb tow and 1,000 lb payload capacity. Actually, it would seem that the increased capacity of 1/2T series trucks to essentially ton capacity has created a bigger space for a true midsize half at this point.
    #67 Tony K, Sep 19, 2020
    cdjr77 and Adventurer55 like this.
  8. sickboy
    Feb 28, 2011
    941
    919
    Think of it as a great money maker.
    3 of the 12 functions stopped working? That’ll be $2800 (Price on eBay for a take off, no idea how much factory new is), $500 To paint it, and $300 for labor.
    personally, I like the ram for forklift loading. But the price is too hard to swallow for something I’d rarely use. A step up To the bed would be all I need. And have it at the corner of the bed. I can use the bed side as a “handle” and the tailgate as a second step. Problem solved
  9. LeeRyder
    LeeRyder Well-Known Member
    Dec 1, 2006
    865
    554
    I see both sides.. for most, the options are not relevant.. especially given the premium pricing.
    That side.. a motorcycle friendly built in ramp would be a wise idea for engineers.
    Loading a bike in a truck bed is a real pain that brings sweat to everyone's palms.
  10. Adventurer55
    Nov 9, 2015
    3,413
    4,437
    Could another problem with a storable ramp be that they need to be longer then most beds?
    burtstwins and kevin m. Henry like this.
  11. LeeRyder
    Dec 1, 2006
    865
    554
    They can make them extendable, like ladders.
    Doug D and Tony K like this.
  12. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    6,019
    735
    Lot more room needed.
  13. 68RT
    Aug 8, 2003
    6,019
    735
    OR. Drop the step portion when you have a bumper hitch installed.
  14. gminnebo
    gminnebo Well-Known Member
    May 2, 2006
    134
    63
    Ha ha, no*, ram boxes get completely different beds, basically they close in the the wheel wells, all that space is dedicated to the boxes. * I mean technically you could get another bed from a Ram that has them and make a swap, but $$$.
  15. burtstwins
    burtstwins Well-Known Member
    Nov 29, 2008
    753
    244
    two choices,
    1)a lot more heavier and thicker to handle same weight
    2} so flimsy that it is worthless
  16. LeeRyder
    Dec 1, 2006
    865
    554
    I've actually worked out 3 or 4 viable methods of making this work since this post.
    Tbh, I'm astonished the manufacturers haven't done it yet. Perhaps the market isn't there, but its absolutely doable.
