Broken trans cooler fitting
Discussion in 'Repairs, Maintenance, Help' started by neoncrazy101, Nov 27, 2017.
  1. neoncrazy101
    neoncrazy101 Member
    Mar 17, 2014
    51
    4
    Hey guys, I have a broken transmission cooler line fitting that snapped off inside the transmission and left maybe 1mm of the threads exposed. Any hints on how to get the rest off? I tried some screw extractors but they all couldn't get the rest to bulge and I really don't want to have to try to drill it out and cause a bunch of shavings...
    BTW, its an 05' Neon ATX.
  2. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    3,134
    400
    Try and apply some heat with a torch to the outside boss area where the cooler lines nipples are threaded into the transmission. The case is aluminum so with some heat it should expand enough and break the bond with the nipples to allow you to use a screw extractor. As you apply heat try and rotate the extractor clockwise and counterclockwise a little bit and work the threads loose. See attached image.
  3. AC TC
    AC TC Well-Known Member
    Dec 3, 2004
    2,520
    347
    Weld a nut on it.
  4. ImperialCrown
    18,232
    2,660
    The cooler line fitting threads have a threadlock/sealant on the threads. This threadlock can be stiff when cold and softens with heat.
    As Allan suggests, I would try warming the area and then use a screw extracting tool to try and unscrew the broken piece out:
  5. neoncrazy101
    neoncrazy101 Member
    Mar 17, 2014
    51
    4
    Thanks guys, I tried the heat unsure if it worked or not but I got the piece out. After heating it up and then after about another 10 min. of me thinking "This extractor is going to snap!" It finally broke the threads loose and I got it out. I was at that point though of, if it breaks it breaks I got nothing to loose at this point lol.
    Quick question though, when I get the new one, do I need to use some type of teflon sealing tape or anything?
    ImperialCrown likes this.
  6. AllanC
    Jan 6, 2003
    3,134
    400
    I would suggest you use teflon pipe sealing tape or anti-seize compound to prevent corrosion due to dissimilar metal (steel fitting in aluminum threaded housing).
  7. Bob Lincoln
    Jul 10, 2002
    29,879
    3,258
    Threadlocker, just like the original. Loctite is the most popular brand.
