Building a 318
Discussion in 'Performance' started by PCRMike, Apr 22, 2017.
  1. RalphP
    Aug 26, 2014
    94
    32
    Something to keep in mind.
    At about 355,000 miles the 999/998 in my 1988 Dakota (3 speed auto) decided to start sounding like a cement mixer with just some large chunks of rock in it.
    My mechanic came to my house and drove the truck up on the flatbed trailer; he then drove it off at his shop and drove it onto the rack.
    He tried replacing the torque converter bolts; no bueno.
    So he pulls the torque converter, finds where my transmission leak is (the front pump) and that the torque converter "rattles".
    So he pulls the transmission and takes it to his transmission guy.
    The transmission guy dumps shrapnel out of the torque converter, and is calling the mechanic a liar for saying he drove it onto the ramp.
    The transmission guy's older helper comes over, looks at it, says, "Oh, it's a Torqueflite. Naw, $MECHANIC drove it fine. That don't hardly faze one."
    My point? Keep the bands adjusted, keep the fluid and filter changed, don't try to do 5 second 1/4 miles on it in a 2+ ton vehicle, and that sucker MAY outlast you.
    (The bad rap most TorqueFlite transmissions have, is more because of people not maintaining them.)
    RwP
    AHBGuru and PCRMike like this.
  2. PCRMike
    PCRMike Well-Known Member
    Mar 3, 2010
    1,865
    705
    I agree with you. I have never had trouble out of ours. I just wanted to see if it would handle 400+ horsepower out of a 318 without turning itself into a grenade.
  3. PCRMike
    Mar 3, 2010
    1,865
    705
    I just found it is a 46RH, not a 42RH. I actually looked at it. Lol.
  4. PCRMike
    Mar 3, 2010
    1,865
    705
    727 based. Will have no problem holding the power after it is built.
    dana44 likes this.
  5. SE Charger
    SE Charger Well-Known Member
    Jul 31, 2009
    763
    151
  6. AHBGuru
    AHBGuru Active Member
    Mar 22, 2015
    202
    87
    Mopar Action is a good sources for information also,[/QUOTE]
    Start with MA. Doctor Ehrenberg explains quite clearly that the same (or less) money dumped into a 318 actually makes a 360 even more of a bargain. As he likes to point out, the 360's long arms (stroke) is where the fun comes in. 400 hp in a 360 is a starting point these days.
    Or, a newer (09+) Eagle Hemi would liven things up, too. But you can swap out an excellent 5.9 Magnum, including the EFI, for the same or less than what building a 318 will cost.
    You can build a 999 to withstand anything, don't let the 727 fans BS you about that.
  7. PCRMike
    Mar 3, 2010
    1,865
    705
    This short block was already machined and assembled. Lol. I am changing to a steel crank I have spare, and custom porting the Magnum heads, so 400 horses is very attainable and will have almost no money in it. It will be a good starter motor for him to train on. The real fun happens when we stroke a poly....mwahahahaaaaa
    dana44 likes this.
