AF: Change the metric wrenchs | Page 2 | Allpar Forums
Discussion in 'Off Topic But Still Civil' started by voiceofstl, Sep 24, 2020.
  1. Bob Lincoln
    Jul 10, 2002
    31,921
    5,245
    Fire hydrants have pentagonal heads on the valve stem, just for this reason - to deter tampering. We had a large ratchet wrench with the 5 sides welded together to make the socket, you could see the welding bead. They are available at some plumbing supply stores only to fire depts.
    DC-93 likes this.
  2. Mastertech63
    Supporter
    Jun 14, 2014
    113
    111
    I have a socket set from craftsman that is 30 years old. It has 19/23 and 25/32 sizes that I have NEVER used and never once felt compelled to complain. And while we are at it, tell GM to get rid of 5.5 mm headed bolts. I had to buy that socket extra because it wasn't in my set of Snap-on sockets. Now I have a socket that has no place in the socket tray!
    DC-93, Tony K and ImperialCrown like this.
  3. Tony K
    Tony K Active Member
    Jan 11, 2019
    924
    1,323
    Brake lines. From what I've read, it's not an ISO, ANSI, DIN or JIS size. Every standard has it's own logic. If you have 500 bolts in a machine, pretty soon, all of those bolt heads start to add up to some weight if you use a 12mm head instead of an 11mm and so on.
  4. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    2,407
    1,218
    5.5mm?????!!!!!! who ever ok'ed this at GM should get some jail time
  5. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    6,019
    735
    A special bolt limits people from working on a product for a period. Keeps them in house until the market is big enough that someone decides to make it. How about safety hex and Torx wrenches?
    Bob Lincoln likes this.
  6. voiceofstl
    Jan 15, 2010
    2,407
    1,218
    The problem is with metric in the smaller standard sizes there hardly and differance between a 10 vs 11. Its not like 1/2 inch vs 9/16. The odd numbers should be gone.
  7. Tony K
    Jan 11, 2019
    924
    1,323
    Why? There's a standard metric wrench for each nominal thread diameter. If one national/regional automotive standard/mfr fails to adhere to that, blame them, not the wrench seller.
    MetricWrenches.jpg source: Wrench size - Wikipedia (at https://en.wikipedia.org/wiki/Wrench_size )
    MJAB, Bob Lincoln and page2171 like this.
  8. 68RT
    Aug 8, 2003
    6,019
    735
    There are many head sizes for American threaded bolts. My first two weeks as a mechanic were spent sorting out nuts and bolts that had come back from a construction job. They had been all tossed into boxes and I had to sort them by size, length, grade AND head size. They are 1/2 inch to 1 inch bolts and corresponding nuts. I had 3 or 4 boxes for each diameter/length I could see why each member of the erection crew was given crescent wrenches along with the spud wrenches. Try adding #3 and #7 plow bolts. (I found #7 with and without a tang even though all are listed as having a tang).
    Tony K and DC-93 like this.
  9. Tony K
    Jan 11, 2019
    924
    1,323
    That has to be aggravating, to a degree. I know from growing up on a farm, you save EVERY fastener and sizable piece of steel. We have old Gerber baby food jars filled with maybe 50 years worth of small and medium machine screws, bolts, nuts and an occasional odd fender washer or toothed lock washer. Dad keeps a bag of odd fasteners in the combine. I say "odd" but they probably all came from an older combine. It's amazing just how many different sizes and threads/pitches there are. I mean, we have wrenches in the 32ds and 64ths, so when someone complains about having metric wrenches every mm from 4-44 (semi-random numbers) plus 5.5 perhaps, I just kinda shrug my shoulders.
    DC-93 likes this.
  10. voiceofstl
    Jan 15, 2010
    2,407
    1,218
    who is going to tamper with a motor mount bolt?
    DC-93 likes this.
  11. 68RT
    Aug 8, 2003
    6,019
    735
    Someone that wants to do their own work.
  12. Bob Lincoln
    Jul 10, 2002
    31,921
    5,245
    People who tamper with motor mounts by putting in solid mounts that vibrate like crazy and kill the drivetrain.
    Tony K likes this.
  13. page2171
    page2171 Well-Known Member
    Apr 28, 2007
    1,716
    2,593
    Where have you seen a tamper proof bolt on a motor mount? I haven't had to replace a lot of motor mounts, but have never come across tamper proof bolts.
    Doug D likes this.
  14. valiant67
    valiant67 ...
    36,777
    19,600
    My 1999 Town & Country 3.8 had at least one odd ( five sided?) bolt.
    page2171 likes this.
  15. page2171
    Apr 28, 2007
    1,716
    2,593
    Weird, but somehow I wouldn't be surprised.
  16. Catimann
    Catimann Member
    Aug 28, 2020
    15
    5
    I run into strange sized bolts all the time and if there is room you can use the different kinds of multi sockets out there. Otherwise it's go buy another one time. SMH. Just imagine if there was some sort of standardized program for all of this. oil filters would cost a buck and so on. I think the vehicle mfg's don't realize that they do no one any favours going this route.
    voiceofstl likes this.
  17. 68RT
    Aug 8, 2003
    6,019
    735
    You want to put the patent office? How about all those engineers that would not get their name immortalized.
  18. voiceofstl
    Jan 15, 2010
    2,407
    1,218
    Thank you for agreeing with me.
