Changed steering column now speedo/ odometer not working
Discussion in 'Pre-1994 trucks, commercial vehicles' started by upser145, May 28, 2017.
  1. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    After a steering column replacement my speedometer and odo quit working its a 1988 w150 im not sure what i could have done just changing the column to make it quit as i thought the speedo worked mechanically so no wires i could have messed up. Any tips before i pull the whole thing apart
    18,231
    2,660
    I would try to reach up in there and feel if the cable is still plugged into the cluster. Make sure that it is seated into the latch.
    pt006 and Bob Lincoln like this.
  3. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    Can i do it without insturument pannel off
  4. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,524
    240
    Yes, if your arm is thin enough. It will be easier from the right side of the steering column. You can probably look up there with a flashlight and see where it is.
    Just changing the steering column shouldn't have affected the speedometer and odometer, but if both quit working at the same time, the cable should be checked first. If it's connected at the back of the instrument panel, then it might have coincidentally broken. Was it making any noise before you replaced the steering column?
