Checklist, please!
Discussion in 'GFAQ: G-Body Frequently Asked Questions' started by Scstables, Feb 28, 2016.
  1. Scstables
    Scstables Member
    Sep 4, 2005
    254
    8
    Okay. Something is wrong with my 1988 Daytona (just a regular 2.5 engine). It seems it could be electrical as if no energy getting to the starter. The battery seems to have plenty of charge as it's brand new. When I turn the ignition on, the lights all light up however when turning the key all the way, there is NOTHING. No sound, no nothing. Where do I start looking to find out what the heck is going on. Did my 28 year old starter go poof? LOL. I don't know.....
  2. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,403
    374
    You mention a new battery, was there a problem before it was replaced?
    First thing to check is battery terminals, corrosion can cause exactly what you are describing.
    Starter relay is on the drivers side shock tower.
    Loose cable at starter is another possibility, tugging on the heavy starter wire can sometimes make another connection.
    A slight hammer tap on the starter can sometimes get a few more starts if its actually failing.
    Good Luck !!
    Thanks
    Randy
  3. Scstables
    Scstables Member
    Sep 4, 2005
    254
    8
    Thanks Randy. What I have noticed is the light under the hood comes on. However when I open the car door, the light that normally comes on to illuminate the interior does not. However when I turn the key, all indicator words/lights come on like it is supposed to, but nothing happens at all when the key is turned completely. This has happened before, and it was a loose connection. Now it is the part of trying to find it. All while my battery loses charge again because I can't the engine started.... grrrr.
  4. dana44
    Ad-Free Member
    Jun 17, 2002
    19,343
    1,249
    To check the starter you should be able to get a screwdriver in there and short it out like the old ones to see if it clicks and/or turns. They do go bad.
