AF: Chrysler’s “Identity” | Page 14 | Allpar Forums
Discussion in 'Mopar / FCA News' started by 1999 White C5 Coupe, Jan 21, 2020.
  1. aldo90731
    Jul 6, 2010
    9,949
    20,525
    You can get it with 80+ degrees, but without the snow.
    #261 aldo90731, Mar 6, 2020
    HotCarNut and Tony K like this.
  2. Bob Lincoln
    Jul 10, 2002
    31,774
    5,055
    Alignment when replacing an entire strut assembly IS required, and any independent shop charges $90.
    Tony K likes this.
  3. Morty
    Morty Well-Known Member
    Mar 15, 2013
    620
    632
    Great picks!!
    aldo90731 likes this.
  4. Chase300
    Chase300 Well-Known Member
    Oct 2, 2012
    1,697
    1,617
    If you say so...I don't know the Daytona set up...but it would be one of the few 80's/90's FWD McPherson strut vehicle with an adjustment to Camber...which is done with an adjustable top had on the strut.
    Most...like 99% McPherson FWD setups only allow adjustment to the toe...which as I said, is not disturbed with strut replacement.
  5. Tony K
    Tony K Active Member
    Jan 11, 2019
    792
    1,108
    See: Price of Bacon (other foodstuff) in China :D
    Zagnut27 likes this.
  6. valiant67
    valiant67 ...
    36,278
    18,721
    The K based cars had camber adjustments from the factory. However, starting with the LH cars then the Neons and others, the factory struts had no adjustment for camber. But there were “crash kits” using special bolts to give camber adjustments sold as service parts. And many aftermarket struts use a slot instead of a hole, which means camber must be set.
    tlc likes this.
  7. Bob Lincoln
    Jul 10, 2002
    31,774
    5,055
    The Daytonas had adjustable camber via the LOWER bolt of the strut assembly, which had an offset cam shape.
    valiant67 likes this.
  8. valiant67
    valiant67 ...
    36,278
    18,721
    The 90’s cars had much better tolerances, and that adjustment was no longer there, though as I mentioned above, the provision to adjust camber was still available.
  9. 82cordoba
    82cordoba Member
    Dec 3, 2019
    6
    11
    Many aftermarket struts and some factory struts have a slotted lower mount hole to adjust camber.
  10. XRT2SRT
    XRT2SRT Well-Known Member
    Aug 25, 2011
    998
    424
    Me thinks, all late madel H.O. TURBO K-cars had adjustable camber also...IIRC.
  11. Chase300
    Oct 2, 2012
    1,697
    1,617
    Most of those aftermarket adjustment kits are for those that have lowered their vehicle which at that point you DO need to adjust the alignment. I'll take it the K cars had adjustments or a cam bolt in the lower strut mount.
    The "Journey" which was the vehicle of discussion, like all the Chrysler badged Japanese cars from the 90's are simple bolt on struts. There is no cam bolts in the lower strut mount and no adjustable mount. So nothing to mess the alignment up and thus no alignment required.
    Same with the LX cars. No cam bolts or adjustable mounts on the struts.
