Chrysler Patents and Trademarks
Discussion in 'Rumors and Speculation' started by hemidakota, Jun 14, 2005.
  1. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,614
    2,811
    That kind of configuration with cylinders and fuel delivery system are usually used with compressed natural gas and/or compressed natural gas + hydrogen.
    Under CAFE rules compressed natural gas vehicles will have a incentive multiplier for compliance purposes of 1.6 in MY 2017 and phase down to a value of 1.3 in MY 2021, same as plugin hybrids. So one CNG car sold will count as 1.6 cars sold.
    Without protection shield the system looks a little bit like this mounted under a car (that is a CNG Fiat Multipla)
    [​IMG]
    This is another configuration used in Europe a crossover or SUV without the 4x4 system.in the photo a bifuel CNG/gasoline Fiat Panda, same architecture as Fiat Panda 4x4). Same configuration could be used for example for a bifuel Jeep Renegade / Fiat 500X.
    [​IMG]
  2. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,227
    14,737
    The new system appears to have two advantages. First, it's higher up so it's less vulnerable. Second, it's faster to install since it's made and tested as a module.
  3. Dave Z
    Jan 23, 2001
    32,227
    14,737
    #2 is I think already used on Ram pickups?
  4. superduckie5000
    superduckie5000 THE MAD DUCK
    Nov 25, 2002
    2,221
    1,049
    New 3.8/4.0 L Engines? ???????
  5. Dave Z
    Jan 23, 2001
    32,227
    14,737
    V6 or V8?
  6. MJAB
    Oct 4, 2013
    2,614
    2,811
    Some interesting patents from FCA (all capital text since I made paste and copy)
    (WO2015179464) MULTI-MODE MODULAR ELECTRICALLY VARIABLE TRANSMISSION
    https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2015179464
    (US20150231686) METHOD FOR FORMING A SHEET MADE OF AN ALUMINUM ALLOY INTO A COMPONENT OF COMPLEX SHAPE, PARTICULARLY A MOTOR-VEHICLE COMPONENT
    https://patentscope.wipo.int/search/en/detail.jsf?docId=US151422063
    (US20150231685) METHOD FOR MANUFACTURING A CAMSHAFT FOR AN INTERNAL COMBUSTION ENGINE BY EXPANDING A TUBULAR ELEMENT WITH A HIGH PRESSURE FLUID AND SIMULTANEOUSLY COMPRESSING THE TUBULAR ELEMENT AXIALLY
    https://patentscope.wipo.int/search/en/detail.jsf?docId=US151422062
    (WO2015059639) FUEL ELECTRO-INJECTOR ATOMIZER FOR A FUEL INJECTION SYSTEM FOR AN INTERNAL COMBUSTION ENGINE
    https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2015059639
    This one is a fuel injector that can be used in diesel engines to reduce NOx and particulate formation.
    guyverfanatic and Prabhjot like this.
  7. Dave Z
    Jan 23, 2001
    32,227
    14,737
    Not surprisingly, the diesel one is from Italy. I haven't looked at the others yet...
  8. Stratuscaster
    Stratuscaster Vaguely badass...
    Jul 5, 2001
    43,899
    6,651
    313 (G & S: Motor vehicles, namely, passenger automobiles, their structural parts, trim and badges) was abandoned on 1/4/2016.
    1941 SEVENTY FIVE YEARS LOGO was applied for trademark on 1/5/2016.
    BACKCOUNTRY will be published for opposition on 2/9/2016.
    ASPEN was applied for trademark on 11/17/2015.
  9. Mopar392
    Mopar392 Well-Known Member
    Mar 28, 2009
    1,624
    443
    I know this is an old patent from Dumbler's time.. FCA still hold the patent as of Dec 03-2014..
    Is it ever going to happen? How is it different from Ford's Power Stroker?
  10. Hemidakota
    Hemidakota Active Member
    Jan 24, 2017
    597
    368
    TIDBIT: Believe or not, before the days of Subi, Dodge has an earlier boxer design engine patent. Nice to see this post again. LOL
  11. Hemidakota
    Jan 24, 2017
    597
    368
    Rev-matching without gear or clutch position sensors
    Abstract - Rev-matching techniques that do not require a gear position sensor or a clutch position sensor are provided for a manual transmission of a vehicle. The techniques include predicting an intent of a driver to shift gears of the manual transmission based on whether the vehicle is accelerating or decelerating; predicting a shift of the manual transmission from a current gear to a different target gear based on the predicted driver intent; and detecting a trigger condition indicative of the predicted shift of the manual transmission based on a position of a clutch pedal configured to control engagement/disengagement of a clutch of the manual transmission. In response to detecting the trigger condition, a torque request for the torque generating system is modified to obtain a modified torque request, and the torque generating system is controlled based on the modified torque request.
    LINK: United States Patent: 9567920
  12. Hemidakota
    Jan 24, 2017
    597
    368
    Mike I could not find the old thread for patents/trademarks.
  13. Hemidakota
    Jan 24, 2017
    597
    368
  14. Hemidakota
    Jan 24, 2017
    597
    368
  15. Stratuscaster
    Jul 5, 2001
    43,899
    6,651
    Hemidakota likes this.
  16. Mike V.
    Jan 24, 2008
    24,636
    18,178
    Got you covered :)
    Mike
  17. MJAB
    Oct 4, 2013
    2,614
    2,811
    "MOTOR-VEHICLE SUSPENSION SYSTEM OF THE MACPHERSON TYPE, INCLUDING A TRANSVERSE LEAF SPRING"
    20170021686 MOTOR-VEHICLE SUSPENSION SYSTEM OF THE MACPHERSON TYPE, INCLUDING A TRANSVERSE LEAF SPRING
    "A vehicle suspension system of the MacPherson type includes a pair of wheel supports, and two shock absorbers each having a body bolted to a corresponding wheel support with a top end connected to structure of the vehicle. A leaf spring is set transverse to a longitudinal direction of the vehicle, and has a central portion connected to the vehicle structure, and two ends connected to the respective wheel supports. The leaf spring is made of a single piece having opposite ends each having a forked shape, with two prongs made of a single piece with the leaf spring, wherein each prong is connected separately to the corresponding wheel support. The suspension system does not include other connection elements between each wheel support and the vehicle structure so that suspension components can be assembled on the leaf spring prior to installation on the vehicle structure."
    [​IMG]
    [​IMG]
    #778 MJAB, Feb 14, 2017
    Prabhjot likes this.
  18. MJAB
    Oct 4, 2013
    2,614
    2,811
    "(EP3118089) UNDERBODY STRUCTURE FOR A MOTOR-VEHICLE"
    3118089 UNDERBODY STRUCTURE FOR A MOTOR-VEHICLE
    Same architecture -> easier and lower cost variation of width of the body of different vehicles sharing same architecture.
    "A method for the production of motor-vehicle structures, wherein an underbody structure (1) is provided including a floor structure (2), and two side members (17) that are welded to two longitudinal lateral edges of the floor structure (2). Each side member comprises an inner element (19, 20) of side member, welded to a respective longitudinal lateral edge of the floor structure, and an outer element (23, 24) of side member, welded to the inner element (19, 20) of side member. The method envisages the use of a common floor structure suitable both for motor-vehicle structures belonging to a first, lower, segment and for motor-vehicle structures belonging to a second, upper, segment. Each lateral edge of the floor structure (2) has for a prevalent portion of its length a flange (L) vertically bent upwardly and welded to an intermediate wall of the respective inner element (19, 20) of side member."
    [​IMG]
  19. Hemidakota
    Jan 24, 2017
    597
    368
