Chrysler Patents and Trademarks
Discussion in 'Rumors and Speculation' started by hemidakota, Jun 14, 2005.
  1. Hemidakota
    Hemidakota Active Member
    Jan 24, 2017
    597
    368
    Now this is very interesting...Fiat (maybe a Alpha design)
    United States Patent 9,821,857
    Cesarano , et al.
    November 21, 2017
    Motor-vehicle floor panel structure
    Abstract
    A motor-vehicle floor panel structure comprises a front body sub-unit, a central floor sub-unit, and a rear body sub-unit. The central floor sub-unit comprises a front floor structure including a central longitudinal tunnel, a pair of lateral longitudinal beams, connected to the front floor structure and to the front body sub-unit and two intermediate longitudinal beams which connect the central floor sub-unit to the front body sub-unit and which extend at intermediate areas between the lateral longitudinal beams and the central tunnel. The intermediate longitudinal beams are connected to the upper surface of the front floor structure and have portions which extend in a cantilever fashion from the front edge of the front floor structure and which are connected to said front body sub-unit. Due to this feature the floor structure has a lower surface which is substantially close to a regular continuous surface, so as to reduce turbulences in the air flowing under the floor panel structure during travel of the motor-vehicle, with a resulting positive impact on fuel consumption.
    LINK: United States Patent: 9821857 (at http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-adv.htm&r=3&f=G&l=50&d=PTXT&S1=FCA.ASNM.&OS=AN/FCA&RS=AN/FCA )
  2. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,612
    2,808
    Two patents linked each other.
    (US20170225208) METHOD FOR ROLLING METAL SHEETS WITH VARIABLE THICKNESS
    https://patentscope.wipo.int/search/en/detail.jsf?docId=US202132501&recNum=7&office=&queryString=ALLNAMES:(C.R.F.)&prevFilter=&sortOption=Pub+Date+Desc&maxRec=1338
    "... Described herein is a method for rolling metal sheets of variable thickness. The method makes it possible to impress, during rolling, any distribution of areas of increased thickness within a figure corresponding to the plane development of a motor-vehicle component prior to the pressing operation. Impression of the desired distribution of areas of increased thickness envisages simultaneous impression, during rolling, of a further distribution of areas of increased thickness, or compensation areas. ..."
    [​IMG]
    And use of the above patent for a door manufacturing.
    (US20170225547) STRUCTURE OF A DOOR FOR A MOTOR-VEHICLE
    https://patentscope.wipo.int/search/en/detail.jsf?docId=US202132840&recNum=6&office=&queryString=ALLNAMES:(C.R.F.)&prevFilter=&sortOption=Pub+Date+Desc&maxRec=1338
    "... Described herein is a structure of a motor-vehicle door including a multi-thickness metal sheet pressed and shaped to define: a hinge area configured for fastening one or more hinges for connection to the body of a motor vehicle; a panel area configured for receiving an upholstery-trim element for the door; and a frame area configured for receiving a window of the door. The above multi-thickness metal sheet has a first thickness in said hinge area, a second thickness in said panel area, and a third thickness in said frame area. ..."
    [​IMG]
    Note: C.R.F. is the company under which are some FCA european R&D centers.
    superduckie5000 likes this.
  3. superduckie5000
    superduckie5000 THE MAD DUCK
    Nov 25, 2002
    2,221
    1,048
    Sounds Like One Heck of a Complicated Steel Rolling Line !
  4. Hemidakota
    Jan 24, 2017
    597
    368
    Trailer hitch guidance method
    Abstract - A method of providing visual reverse steering guidance indicators on a display in a vehicle includes having an electronic control unit display on a display in the vehicle an image of an area behind the vehicle that includes a target, display a projected path track of a projected path that the vehicle will travel based on a current alignment of a steering system of the vehicle, display a visual indicator of whether the projected path matches a target path that the vehicle must travel in reverse to align the vehicle with the target, when the projected path does not match the target path, displaying a visual indicator of a direction that a steering wheel of the vehicle must be turned to align the projected path with the target path, and updating the visual guidance indicators in real time as the vehicle is driven in reverse toward the target.
    LINK: Patent Database Search: Error (at http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-adv.htm&r=2&f=G&l=50&d= ) FCA 1.png PTXT&S1=FCA.ASNM.&OS=AN/FCA&RS=AN/FCA
    somber likes this.
  5. Hemidakota
    Jan 24, 2017
    597
    368
    I just noticed this morning after GOOGLE NEWS search, some of these patents links were lifted from this site for Russian automotive enthusiasts website.
