AF: Considering 2010 Compass | Allpar Forums
Discussion in 'Compacts: Renegade, Patriot, Compass, Caliber' started by bguy, Nov 9, 2014.
  1. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,779
    165
    Hi all,
    DW and I are considering a 2010 Compass that is for sale at a nearby dealership. Having not yet seen the car in person, is there anything specific to look for as a warning flag to avoid this vehicle, other that the normal caveats with a vehicle this age? It has 2.4 auto w 4x4 and 55,000km.
    Thanks for reading.
    Brian
    ImperialCrown Moderator
    21,113
    4,300
    By 2010, the overall vehicle quality had improved markedly. I know that the older ones had suspension joint wear issues.
  3. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    2,106
    1,374
    I have a 2013 Patriot, and some of the suspension issues are still there, sadly.
  4. MoparNorm
    MoparNorm Active Jeeper
    Aug 2, 2008
    31,138
    7,673
    Ball joints?
  5. gforce2002
    Oct 31, 2003
    2,106
    1,374
    Not sure about this round, I still have to take it in to see about the new noises before the warranty's up. There's something in front and something in back. I can't remember what it was they replaced in back about 15k kms ago (now at 55K kms) - maybe rear sway bar mounts or bushings? I'll have to look back at the work sheet. I will say that it's much better than my 2009 Patriot, which had more suspension issues and earlier in its life.
  6. bguy
    Dec 9, 2007
    1,779
    165
    Well guys wish me luck. We signed on for a 2011 ( I much prefer the body styling ) North Edition with just a tad under 51,000km for a thousand dollars more. We take possession Thursday. I haven't read much about CVT issues as of late. Have they mostly gone away?
  7. browens1534
    browens1534 Well-Known Member
    Apr 6, 2008
    1,872
    58
    Check jeeppatriot.com for more info. The Compass/Patriot MK section on here is kinda dead... I'm there as brycmtthw
    I will attest to CVT issuees.. I bought my 09 with 73k miles on it, CVT nuked itself at 75k.
  8. gforce2002
    Oct 31, 2003
    2,106
    1,374
    Just an update on this - dealer replaced front sway bar bushings and eliminated that sound from the front. I *think* I still hear something from the back, but it's very minor if it's there. Also on the last trip, they had to replace a rear wheel bearing and the driver's door hinge needs replacing again (So counting the original, this will be its third in 57K kms.)
    There is also a vibration through the pedals and sometimes the manual gear shift on acceleration and deceleration around 2000 rpm. They didn't fix that the last trip, but I've rebooked. It has also started shuddering sometimes on releasing the clutch when starting off. I guess a bad motor mount can cause these symptoms?
