AF: Dodge Dart leaving........... | Page 28 | Allpar Forums
Discussion in 'Mopar / FCA News' started by CDJSalesPro, Jul 11, 2016.
  1. tomit
    tomit Well-Known Member
    Apr 16, 2004
    277
    163
    As do a few of almost all brands.
    XRT2SRT likes this.
  2. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    3,364
    3,942
    For example Honda ordered a stop-sale and recall on around 42,129 2016 Honda Civic with 2.0 engine for engine failures. They "just" have wrongly installed piston pin retaining ring or more simply they didn't installed it at all. Maybe someone was trying to simplify engine design at production site :)
  3. somber
    somber 370,000 miles
    Sep 10, 2014
    1,326
    1,883
    Oh man, that yellow NSRT4 - want! I was ready with the cash to buy a Dart SRT or Dart GLH, but sadly, no dice. Hopefully, the Dodge version of Giulia is going to help me forget (I just hope they offer it with a stick).
    eastcoaster likes this.
  4. Hank600ES
    Hank600ES Well-Known Member
    Jul 20, 2014
    557
    370
    Once the Dart, along with the Compass and Patriot ends production at Belvidere, goodbye Hyundai transmissions. I wonder if they want to continue that relationship?
    james.mooney. likes this.
  5. BobbiBigWheels
    BobbiBigWheels The "Front-Line" Perspective
    Jun 2, 2016
    3,245
    4,876
    The DDCT was a great transmission IMO. I thought that it's lack of delay in manual shift mode was phenomenal.
  6. Mike V.
    Jan 24, 2008
    26,427
    22,139
    It's great until the clutches start slipping in traffic... it does like to creep.
    The DDCT in the Dart and 500L has been a nightmare. Had more been sold, it would have been worse than the 9 speed issues. Most of the early DDCT Darts were recalled before they were able to be sold to replace the slave cylinder that was faulty. After that, the transmission has been plagued with TCM failures.
    Mike
    Bob Lincoln likes this.
  7. BobbiBigWheels
    Jun 2, 2016
    3,245
    4,876
    Test-Drive vs ownership experience - great to know Mike.
  8. valiant67
    valiant67 ...
    36,662
    19,401
    Yep great until the clutches go up in smoke in traffic and the car can barely move itself out of traffic.
  9. Lorena
    Lorena Active Member
    Apr 24, 2015
    88
    123
    Slave cylinder? TCM failures...
    Glad I dropped the manual Dart. Ya think a gal driving a stick buying up a stick Dart in cash would be happy.
    Yes.
    Then it became a nightmare of failures. Still have a lockbox for the hydraulic components that FCA refused to replace in case the class action needs some ammo. Inspected, and expected to fail.
    Still in the FCA family, but barely ;)
    Erik Latranyi likes this.
  10. Bob Lincoln
    Jul 10, 2002
    31,880
    5,195
    MUST have a manual transmission somewhere in the lineup, or it's no go for me, for any Mopar.
    somber and dyslexic teddybear like this.
  11. MJAB
    Oct 4, 2013
    3,364
    3,942
    I would more worried about the lost of power assist in 2013-2014 Darts, more than 120k, models with 2.0 and 2.4 engine.
  12. Mike V.
    Jan 24, 2008
    26,427
    22,139
    No problem... see link for slave cylinder info.
    A deeper look at the Dart DDCT fix
    Mike
  13. Prabhjot
    Prabhjot Active Member
    May 4, 2015
    1,361
    1,370
    The decision to have the creep accentuauted on the ddct's usa implementation was a bad one. The ddct+1.4 turbo combination is otherwise very splendid (in europe, also now ddct+1.6 multijet diesel on Fiats and Suzuki-s), and notably reliable relative to VW's dsg and Ford's dual-clutches.
    They might then have managed to secure a place for the usa-made 1.4 turbo in the usa brands' models, thereby bettering both their CAFE performance and suffering less from the 2.0 and 2.4 multiair's being not-quite-competitive. The 1.4+ddct was their initial strategy for good fuel efficiency-yet-fun, but then fuel prices crashed and ddct-s were totally written-off in the usa marketplace (vw's too).
    I guess they did not reckon enough with median American tastes and preferences (larger capacity engines, hatred for turbolag, great liking of the purportedly higher reliability of tc and cvt transmissions).
  14. MJAB
    Oct 4, 2013
    3,364
    3,942
    One recall (around 27.5k Darts) for TCM module in 2013-1025 Dodge Dart was not directly for problems to TCM itself, but by the mounting bracket causing too much pressure on the module's board.
    As is usual in most modern car repair the repair doesn't stop replacing the part, but other operations should be done in order to put properly to work all parts controlled by electronic systems (for example in DCT gearboxes clutches "kissing points" and similar parameters).
    Don't know if it is the same of the Dart recall, but in Europe there were a recall on 2012 or 2013 Alfa Romeo models, for hydraulic actuator leaking from o-ring (were replaced o-ring and actuator).
    [​IMG]
    The other actuator, that was not interested by the recall, is on the opposite side of the gearbox, rear the clutches.
    [​IMG]
  15. Mike V.
    Jan 24, 2008
    26,427
    22,139
    This is a much bigger problem than you are making it out to be. The car goes into the limp mode or shifts intsef into neutral and is stuck. To make matters worse, a dealer has to get authorization to order a replacement TCM, they can only order one at a time, and the cars stack up. The issues is bad solder connections in the TCM. The original recall went out and people got repairs only to have the same issue happen again. That when they finally started replacing the TCM'a in general.
    Cars shifting themselves into neutral is a serious safety issue. My local dealer has had three to five cars parked for dead TCM's... they have to replace one at a time so the cars sit for weeks at a time with extremely disgruntled owners waiting for repairs that can take months to complete.
    It's a huge problem that has been swept under the rug. Had the Dart sold more volume it would be an incredibly large black eye for FCA. They got lucky on this one.
    Mike
    Ian, Bearhawke, jerseyjoe and 4 others like this.
  16. MJAB
    Oct 4, 2013
    3,364
    3,942
    It is not me, it from recall description by media. And has to do with the braked damaging the TCM.
    And for repairs for me the repair date should be "yesterday".
    The part about o-ring is for the models that were repaired also at dealers before went into customers hands, Two separated recalls.
  17. Mike V.
    Jan 24, 2008
    26,427
    22,139
    Agreed... they have dropped the balls hardcore on these repairs.
    A coworker's son was directly affected by this so I know a great deal about it as I ended up directly involved.
    Mike
  18. redriderbob
    redriderbob Mopar Guru!
    Supporter
    Feb 22, 2004
    12,765
    23,203
    Ok, enough of the bad things about the Dart... lets remember some of the good things...
  19. Mike V.
    Jan 24, 2008
    26,427
    22,139
    Neither one of those are "production" Dart's. :)
    Both are dedicated racecars with non-production drivetrains :)
    I like the RWD one the best ;)
    Mike
  20. redriderbob
    Supporter
    Feb 22, 2004
    12,765
    23,203
    I said remember the GOOD things... I figured with my sarcasticness you would catch on!
    Mike V. likes this.
