AF: Engine Compartment Wiring Diagram | Allpar Forums
Discussion in 'Minivans · Pacifica' started by slim slow slider, Oct 17, 2020 at 10:46 PM.
  1. slim slow slider
    slim slow slider Well-Known Member
    May 19, 2012
    429
    39
    Is 88 the same as 89?? 2.5 engine. Doing a changeover and a diagram would be helpful. Have the 88 shop manuals, but not the 89.
    Transferring engine/tranny from an 89 into an 88 Caravan. 2.5 engine.
    Most appreciative if someone here can help!!
  2. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,573
    1,150
    Attached is the PCM connector pin outs for 1989 Plymouth Acclaim / Dodge Spirit twins with 2.5 liter 4 cylinder engine. PCM pin outs are the same. Pin #6 and pin #46 on the 1989 version are used to supply information for the mini trip computer. Otherwise connector pins are identical with 1988 so you should not have a problem with the engine swap.
  3. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,989
    680
    1988-1989 Engine compartment wiring harnesses are functionally the same.
    Lots of Engine differences between the 1988-1989 2.5 TBI 4 cylinders.
    89 is common block with shorter timing belt, reverse rotation water pump etc.
    Exhaust pipe may need a slight tweeking.
    Thanks
    Randy
  4. slim slow slider
    May 19, 2012
    429
    39
    Great! Thanks very much for the information. Helps greatly!!
  5. slim slow slider
    May 19, 2012
    429
    39
    FYI: Doing a changeover in the swap. Taking out a 3.0 and installing a 2.5. Hate that 3.0. 3.3 better engine IMHO.
  6. GLHS60
    Jun 23, 2008
    1,989
    680
    Original post wasn't clear.
    "Transferring engine/tranny from an 89 into an 88 Caravan. 2.5 engine."
    Thanks
    Randy
