Engine/transmission Bell Housings
Discussion in 'Repairs, Maintenance, Help' started by TWX, Aug 19, 2009.
  1. 604 expert
    604 expert Member
    Apr 19, 2008
    108
    The A404, A415, A470, A670, and A962 transaxles are basically identical except for the bell housing patterns
    except for the turbo, which did not have lockup,or a hole for the plug for the lockup solenoid
  2. TWX
    TWX DO NOT FEED THE TROLLS!
    Jan 23, 2003
    8,809
    77
    I see that I'm going to have to go through these three pages of replies to my original post to revise it. It's been some time since that original post was made, so this might take awhile. Thank you everyone, for contributing to this. Hopefully this will make interchange a lot easier for a lot of people.
  3. dana44
    Ad-Free Member
    Jun 17, 2002
    19,326
    1,238
    I was thinking about that the other day, FWD is FWD, but still unclear if to go RWD there are any RWD transmissions that will attach to those primarily FWD engines unless you get an engine/transmision setup out of a Jeep.
    Have fun, and how is that assembly coming along?
  4. sword181
    sword181 New Member
    Nov 10, 2011
    2
    I am a little lost. Will a late 2011 Jeep 3.8 bolt up to 727? Thanks
  5. jerseyjoe
    jerseyjoe Plymouth Makes It
    Apr 13, 2002
    7,467
    1,686
    Prowler had the trans moved to the rear also.
  6. dana44
    Ad-Free Member
    Jun 17, 2002
    19,326
    1,238
    Makes it a transaxle, right, with a torque tube to operate. Good way to balance a vehicle. Corvette uses the same thing, engine in the front, torque tube, and transaxle in the rear. Couple of the European performance cars do, too.
  7. triple j
    triple j Guest
    Remember that AMC v-8's prior to 1972 had a different crank pilot and will bolt up but need special converter. Check with guys on AMO site.
  8. aaaroaddog
    aaaroaddog Member
    Oct 3, 2013
    2
    what are the cu in's of a C48-40968
  9. TWX
    Jan 23, 2003
    8,809
    77
    I have no idea what you're talking about...
  10. kerrymann
    kerrymann New Member
    Mar 12, 2014
    3
    I am new to the forum but had to say that this post has very helpful. And thanks to everyone that contributed I have a '88 2.2L from a dakota that I need a tranny for. They are hard to find nowadays and won't handle the 330ftlbs that the motor puts out anyway.
    Based on what I have read here the 2.5l in 96+ has a different engine block bolt pattern correct from the 2.2l K motors?
    But if I get a bellhousing from a 94-96 dakota then it opens up a world of different 5 speeds, like the AX15?
    Thanks in advance!
  11. valiant67
    31,680
    10,956
    Welcome. The Dakota used the 2.5 Chrysler 4 (derived from the 2.2) through 1995 so those share your bolt pattern.
    The 1996 and up 2.5 is an AMC derived motor so those won't fit. Be careful with 1995, I've seen claims that some 1995 models may have the AMC engine.
  12. szegecs
    szegecs New Member
    Mar 13, 2014
    5
    hello.
    I have a question.
    have a 1994 Town & Country.
    the automatic transmission is broken.
    the renovation is expensive.
    you do not know what manual transmission would be for the 3.8 V6 engine together?
  13. valiant67
    31,680
    10,956
    There is no manual transmission confirmed to fit the 3.8 V6 engine. There's a possibility the manual transmission from the Sebring GTC and Stratus R/T sedan might fit but it has never been confirmed to work.
  14. szegecs
    szegecs New Member
    Mar 13, 2014
    5
    thanks for the reply.
    Unfortunately, you have to find another way.
    perhaps the "93-94" and voyager 3.3 automatic transmission can be as good?
  15. valiant67
    31,680
    10,956
    The 3.3 transmission from 93-95 should work with your engine. It will bolt up but the gear ratios would be slightly different.
  16. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,604
    335
    For the record: I had a 1994 Dodge Caravan 3.3L and the AT in it worked quite well. I say that because the 3.3L and 3.8L are essentially the same engine.
  17. kerrymann
    Mar 12, 2014
    3
    Thanks. That is what I wanted to hear. I ordered a AX15 from a 95 dakota today with bellhousing and shifter. I'll let you know how it goes.
    My next step is finding a clutch that can handle +350 ftlbs of torque. :)
  18. szegecs
    szegecs New Member
    Mar 13, 2014
    5
    köszönöm
  19. floridaman2013
    floridaman2013 Active Member
    Oct 17, 2013
    1,113
    320
    Isn't that 3.8 engine the same one in the Jeep Wrangler? If so, they have a manual Transmission too. Or does it have a different bolt pattern?
  20. valiant67
    31,680
    10,956
    The 3.8 transmission in the Wrangler won't help in a FWD minivan. It will not fit as the Wrangler mounts the 3.8 longitudinally rather than transverse. There won't be room under the van hood for the Wrangler transmission.
