AF: ES interior trim color code | Allpar Forums
Discussion in 'Minivans · Pacifica' started by Kevin1990, Sep 20, 2020.
  1. Kevin1990
    Kevin1990 Active Member
    Apr 18, 2010
    697
    17
    Gent's,
    My 1995 caught fire while welding (previous ownor).
    The rear quarter panel has fire damage, rare to find over here.
    I found some numbers behind one interior trim, but dont know what number (maybe) the color is...
    Thanks again,
    Kevin
    ImperialCrown Moderator
    21,259
    4,451
    The plastic sticker on the door if still readable, would have the paint code (PNT) and interior trim code (TRM).
    [​IMG]
    The stamped metal body ID tag under the hood should also have the codes.
    [​IMG]
    The (1994) exterior and interior color codes are on p. 23-5 here. They should be similar to 1995:
    http://oskin.ru/pub/chrysler-dodge/...4_AS_Town&Country_Caravan_Voyager/94AS_23.PDF
    Due to age and fading, the code may not be a perfect tint match. A good body shop should be able scan and mix a close match.
    Kevin1990 likes this.
  3. valiant67
    valiant67 ...
    36,777
    19,601
    The numbers on the trim piece won't tell you the color because they use the same mold for every color. They may have a paper decal attached that would have the color but it's probably long gone. As mentioned above you can find the color code. The Chrysler part number will have the color as part of it.
  4. ImperialCrown
    21,259
    4,451
    The last 3 characters may be part of the trim code. Hard to tell as some interior parts were P.A.R. (paint as required).
    4 interior colors are listed for the 1995 minivan (see INF trim information section in parts catalog link below): Slate Blue (B7), Medium Quartz (D5), Crimson Red (M6) and Driftwood (D6).
    Figure IAS-240 shows the RR 1/4 trim panel (item #1) for SWB minivans here:
    http://oskin.ru/pub/chrysler-dodge/manuals/Chrysler_Service_Parts_Catalog/CD2/82-96PassCar/95P.PDF
    Note that the last 2 characters in the part # are the trim color.
  5. Kevin1990
    Apr 18, 2010
    697
    17
    Thank you guys, hope i have some luck cause its an EU model, made in Austria. They had different colors over here, but i guess stickers etc are the same.
