AF: Fate of the Hemi 5.7? | Page 5 | Allpar Forums
Discussion in 'Mopar / FCA News' started by andronikus, Feb 27, 2016.
Thread Status:
Not open for further replies.
  1. grungerockjeeper
    grungerockjeeper Well-Known Member
    Jul 17, 2012
    704
    685
    So how would this low sulfur fuel affect older engines? Is it going to be a scenario like when unleaded became the norm and you either ran lead additive or had to rework the valve seats to cope?
  2. grungerockjeeper
    Jul 17, 2012
    704
    685
    Some guy on youtube has a setup like that on a /6. Its pretty sick!
  3. grungerockjeeper
    Jul 17, 2012
    704
    685
    Id define 'safety' a bit differently then. One such delay occurred right as I came out of the 26 West tunnel out of Portland. My truck caught up to my lead foot right as I exited the tunnel (back onto wet pavement) and I found myself sideways! Luckily no one was on my right quarter...
    jerseyjoe likes this.
  4. Mike V.
    Jan 24, 2008
    26,427
    22,139
    The formulation is different and it is called "low sulfur" because it has a lower content of sulfur in it. Sulfur is not a catalytic convertir destroyer like lead was/is (since you mentioned the unleaded fuel change over) but it is an inhibitor which strongly competes with the other exhaust pollutants on the catalyst surface. When combustion occurs, fuel sulfur is oxidized mostly sulfur dioxide (SO2) and a small amount of sulfur trioxide (SO3). SO2 and SO3 are known to inhibit the function of the catalytic convertor.
    The affects of sulfur vary based on gasoline sulfur level, the catalyst formulation, catalytic function, combustion products from various air/fuel mixtures, and exhaust temperature range.
    As for carbon build up, low sulfur fuels have been shown to have lower particulate matter content emissions upon combustion, which will help with DI engines and the occurrence of build up.
    No, it won't affect valve seats but may require some changes in carburetor tuning on older vehicles because of changes in air/fuel mixture and combustion temperatures when burning low sulfur gasoline.
    Mike
    #84 Mike V., Mar 3, 2016
    grungerockjeeper likes this.
  5. redhed
    Feb 7, 2002
    1,940
    418
    so what it boils down to is that while catch cans are nice...and "cleaner" burning gas is nice...they aren't the complete answer to eliminate carbon buildup on the intake valves. :cool:
  6. Mike V.
    Jan 24, 2008
    26,427
    22,139
    If that's the conclusion you want to make... However, that's not what I said. ;)
    Mike
    #86 Mike V., Mar 3, 2016
    redhed likes this.
  7. ptschett
    ptschett Well-Known Member
    Dec 30, 2004
    844
    144
    Depends on the definition of "drone". I had a 2010 5.7/6-speed manual for about 4.5 years which I traded for a 2015 5.7/8-speed automatic about a year ago. While I think the steady-state or gentle-acceleration sound of the engine in 4-cylinder MDS mode (after all that experience with the non-MDS manual setup) can be a little weird, I wouldn't call it objectionable at all.
  8. Max Wedge
    Max Wedge Well-Known Member
    Oct 18, 2013
    972
    474
    That would be my guess in this situation perhaps one of the other guys here could give you some better more detailed answer.
  9. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    14,553
    4,035
    Never really noticed any sort of MDS drone with my '06 1500, but then mine did not have dual exhaust. I think it's more noticeable if there is dual exhaust.
  10. MPE426HEMI
    MPE426HEMI Well-Known Member
    Oct 21, 2008
    4,365
    4,267
    Never hear any weird drone noises out of my '06, with duals when I had MDS, but then I never took my foot out of it anyways.:)
  11. aldo90731
    Jul 6, 2010
    10,269
    21,612
    The reason I ask is my 2012 300 SRT 6.4 HEMI with 5-speed droned at freeway speeds. It drove me bananas.
    My Challenger 392 with 6-speed didn't have MDS, so I didn't hear it in it.
  12. MPE426HEMI
    Oct 21, 2008
    4,365
    4,267
    I have mine deactivated, but when I had it on, I never noticed any irritating drone at highway speeds. I've read somewhere that the dual exhaust was set up in such as way as to combat this. Changing over to an aftermarket exhaust however, may produce it.
  13. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    34,958
    20,692
    And for those who don't remember what it's like to have older cars... we have to tune the carburetor on a regular basis anyway...so it shouldn't really matter. Aside from refiners' conversion costs, this is really a no-lose change.
    valiant67 and Mike V. like this.
  14. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    6,726
    10,230
    @ MRGTX
    What happens when your aluminum block becomes heavier than an iron block because of durability issues? There are very good reasons for keeping "old" technology in service and aluminum does not always equal lighter.;)
    #94 GasAxe, Mar 4, 2016
    Mike V. likes this.
  15. valiant67
    valiant67 ...
    36,699
    19,477
    Carburetor tuning , points and plugs were all about once a year issues.
    Mike V. likes this.
  16. Mike V.
    Jan 24, 2008
    26,427
    22,139
    The ethanol mixed in the fuel causes more issues with older cars than the reduction of sulfur content in new formulations will.
    Mike
    grungerockjeeper and GasAxe like this.
  17. Dave Z
    Jan 23, 2001
    34,958
    20,692
    I did the carb tuning twice a year but my car had over a hundred thousand miles (pick one, any car.) Yes, the ethanol is a bigger issue ... though it's not the end of the world, either. Unfortunately it seems unlikely a better solution will be found since ethanol is so big in the primary states...
  18. Mike V.
    Jan 24, 2008
    26,427
    22,139
    Careful, let's not get political :)
    But yes I agree, it's here to stay, in all its gummy nasty glory.
    Mike
  19. Dave Z
    Jan 23, 2001
    34,958
    20,692
    Sorry. You are right of course. May I just say I think it's a non-party-related issue? If you represent corn farmers, you want to see a higher price for corn. It is rather far from the fate of the Hemi, though, and we should return to that.
    Mike V. and valiant67 like this.
  20. TheMan
    TheMan What color are the clouds in your world?
    Sep 19, 2002
    30,506
    6,002
    Eifh fje 11.r fo 1 zc of '5my s8 ... I do notworrry about [email protected]
Thread Status:
