AF: FCA Preparing to Recall Approximately 1 Million Vehicles for Emissions | Page 2 | Allpar Forums
Discussion in 'Mopar / FCA News' started by 1999 White C5 Coupe, Aug 5, 2020.
  1. turbonetic
    turbonetic Active Member
    Jul 23, 2019
    157
    211
    They'd just give you a BS excuse anyway. My Abarth has used oil quarts between changes since new and they did their little test and told me "it basically a racing engine, they use oil" Gee thanks. There's no way someone could drive it and make it to another oil change without it running extremely low or dry all together.
    UN4GTBL and gforce2002 like this.
  2. prowler
    prowler Well-Known Member
    Apr 28, 2012
    176
    84
    Has there been as bad run of catalytic converters or are some saying that excessive oil consumption has ruined them?
    I'm sure FCA doesn't manufacture converters so it must be a vendor issue with quality control.
  3. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    2,149
    1,460
    When they implemented Multiair, they also moved to a much thinner oil requirement. Whether those are related, I'm not sure. In any case, my belief is that they changed the oil viscosity requirement without doing any reengineering to the rest of the engine. If you're lucky enough to get one that had pretty close tolerances, then you're lucky. If not, you're burning oil like crazy.
    Dave Z and tlc like this.
  4. gforce2002
    Oct 31, 2003
    2,149
    1,460
    If you have one of the affected engines, I don't think anyone really starts to become aware there's an issue until the engine suddenly and without warning shuts down. This can be on a side street (like mine did thankfully) or in the middle of a busy highway. Mine even activated the electronic parking brake. FCA has determined that burning one litre per 3000 kms is "normal" and anything less than that is perfectly acceptable. So, I'm left to go back to the dealer every few weeks for an oil top-up.
  5. IronMike3406
    IronMike3406 Well-Known Member
    Jun 9, 2012
    248
    398
    Our 2018 Renegade has no oil burning issues. We run 5000 miles between oil change intervals I do check my oil at every fill up. Must've gotten a great one. But then again I am a fanatic about maintenance on vehicles.
  6. valiant67
    valiant67 ...
    36,777
    19,601
    It has nothing to do with maintenance when a brand new car goes through 3-4 quarts of oil in less than 2000 miles. You either get a good one or a bad one. Most people likely get a good one, but there is a large number of bad ones out there.
    UN4GTBL, Doug D, tlc and 1 other person like this.
  7. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    35,032
    20,792
    A longtime issue for BMW and GM owners comes to FCA...
    It does sound like the issue is the thin oil, since the 2.0 TigerShark, as I recall, does not have MultiAir or any of these problems.
  8. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    3,420
    4,033
    If I am not wrong the 2.0 and 2.4 Tigershark engines use the same oil grade.
    Checked. 2016 Dodge Dart owners manual
    "... Engine Oil Viscosity (SAE Grade) — 2.0L And 2.4L Engine MOPAR SAE 0W-20 engine oil or equivalent Pennzoil orShell Helix is recommended for all operating tempera-tures. This engine oil improves low temperature startingand vehicle fuel economy. Your engine oil filler cap alsostates the recommended engine oil viscosity grade foryour engine."
    "... Engine Oil Viscosity (SAE Grade) — 1.4L TurboEngine MOPAR SAE 5W-40 synthetic engine oil approved toFCA US Material Standard MS-12991 such as Pennzoil,Shell Helix or equivalent is recommended for all operat-ing temperatures. This engine oil improves low tempera-ture starting and vehicle fuel economy. ..."
    The 1.4 has the MultiAir module, but uses a 5W-40 oil grade.
    Alfa Romeo Giulia 2.0T MultiAir (GME engine) oil is Mopar API SNPLUS Certified SAE 0W-30.
    #28 MJAB, Aug 8, 2020
    Stéphane Dumas, tlc and ScramFan like this.
  9. T_690
    T_690 Well-Known Member
    Aug 31, 2015
    3,529
    4,630
    1.3 turbo?
  10. gforce2002
    Oct 31, 2003
    2,149
    1,460
    It’s possible the 2.0 does have the problems but the total numbers are so much smaller the issue may not be reported much. All complaints I’ve read (and there are tons) have been the 2.4 though.
  11. MJAB
    Oct 4, 2013
    3,420
    4,033
    For european market these are some of the oils grades used in engines.
    Gasoline engines
    - oil SAE 0W-30 ACEA C2 / API SN technical specification 9.55535-GS1 for 1.4 Turbo Multi Air, 1.0 Turbo Firefly and 1.3 Turbo Firefly (150 CV and 180 CV)
    - oil SAE 0W-20 API SN technical specification 9.55535-CR1 for 2.4 Tigershark
    Diesel engines 2.0 16V Multijet and 1.6 16V Multijet
    - without AdBlue (urea) system: SAE 0W-30 ACEA C2 technical specification 9.55535-DS1
    - with AdBlue (urea) system: SAE 0W-20 ACEA C2 technical specification 9.55535-DSX
  12. Dave Z
    Jan 23, 2001
    35,032
    20,792
    I guess maybe there just aren't a lot of 2.0s out there.
  13. T_690
    Aug 31, 2015
    3,529
    4,630
    What's the difference?
  14. WXman
    WXman Active Member
    Oct 28, 2014
    922
    1,167
    Yes, because it's under warranty and she doesn't want to get rid of it right now anyway. As it nears the end of powertrain warranty we'll start looking to trade it. In the meantime I've just been using higher viscosity oil which slows down the consumption considerably and is probably better for the engine anyhow. This thing runs HOT under the hood. 5W40 is probably best.
  15. DC-93
    DC-93 Well-Known Member
    May 1, 2014
    3,221
    2,092
    No use of oil!! Yeah!!!!!
    page2171 and Zagnut27 like this.
  16. edvan
    edvan Well-Known Member
    Apr 10, 2002
    257
    127
    I only buy FCA products, my wife only buys Subaru. A world of difference. Luckily, I have had few problems with my vehicles, but the service my wife gets from Subaru is amazing. A few years ago, there was a three month wait for her next Subaru. She called Subaru of America and they sent her a check for $1000. We have a joke in our family, if I have a problem, Chrysler sends me a brochure, if she as a problem Subaru sends her something like a beautiful blanket. In the last few years, most of our neighbors have bought Subarus. It is not just the car, but the service from SOA. I have been buying FCA since 1969, I am convinced they will never come close to the support of SOA.
