First post 88 Plymouth Grand Voyager
Discussion in 'Welcome to Allpar!' started by Billsgvoyager, Jul 1, 2017.
  1. Billsgvoyager
    Billsgvoyager New Member
    Jul 1, 2017
    4
    1
    Yesterday my girlfriend & I drove 3 hours to grab my Brandnused 88 Plymouth Grand Voyager.
    Fully loaded, fake decal wood grain. 499650 kms. The van hadn't run in over 15 years.
    I plated it, it'll take an easy 6 hours to clean in and out, I'm talking scrub it.
    It comes with original wire caps and bolts to secure the caps. First purchases gas and wiper blades as it down poured. Definitely replacing the windshield, major cracks. Everything still works air and we had the cruise going. I'll do the oil change next pay day, and air filter, spark plugs.
    I have plans for this beast, next year I can plate it Antique. I'm taking care of it slowly.
    wolfsblood07 likes this.
  2. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,796
    459
    Welcome to Allpar. I'd HIGHLY recommend going through the brake system. Dry rotted and shrunken seals could cost you your life.
  3. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,143
    1,647
    I'd replace all coolant hoses and belts as well.
  4. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,524
    240
    Welcome, and good luck with your purchase. After sitting for 15 years, you're lucky that it still runs. In addition to the other advice, you might also drain and replace all of the fluids. One friend reported that a Chevy S10 his dad purchased started knocking at high speeds after a few years, so they had to replace the engine. The mechanic told them that crud had caked in the oil pan, so you might want to pull the oil pan and examine it. Perhaps its gasket needs replacing. Check the tires, too (including the spare); dry rot in the sidewalls might cause a blowout. More advice will doubtless be forthcoming.
  5. Doug D
    Aug 10, 2000
    12,143
    1,647
    Definitely replace the tires. Any tire older than 10 years should be replaced. There should be a 4 digit date code on the tire (week/year). I have no doubt if the vehicle has been setting for 15 years the tires are probably showing signs of dry rot and are unsafe. If it were me, I'd replace the tires.
    I agree with Scrounge - replace all fluids (coolant, oil, power steering) as well. So long as the AC is not showing any signs of leakage it should be okay. Exhaust may eventually need replacement.
    Vehicles are not made to sit, but need to be driven on a somewhat regular basis.
  6. Billsgvoyager
    Jul 1, 2017
    4
    1
    I'll be replacing the oil and filter and air filter in two weeks along with antifreeze. I'll also look at replacing the oil pan gasket first.
    I'm looking at replacing the valve cover seal as well since it's leaking.
    These are the first items to be replaced, I'll be doing the brakes for sure and fuel filter.
    Lines will definitely be replaced.
    Thank You all for your input, I'll be getting busy asap.
    How do I post pics by the way.
  7. pt006
    pt006 Active Member
    Dec 24, 2014
    1,284
    491
    I don't know what engine you have, but I've had a 2.2 and a 2.5 and never had an oil pan leak. Had to replace valve cover gaskets on both of them. Use factory recommended plugs. Check the hoses behind the valve cover.
    When doing the brakes, replace the calipers and the front brake hoses. They both came back to haunt me within a year or two. And while you're doing the back brakes, check the E brake cables. And spin the tires when the drums are off to check the bearings for noise. Clean and repack them if you have roller bearings.
    Can you lay a 4 x 8 sheet of plywood in the back ?
  8. Billsgvoyager
    Jul 1, 2017
    4
    1
    I'll check the engine size again. Take both back seats out I can lay 4 x 8 sheets of plywood down.
  9. Billsgvoyager
    Jul 1, 2017
    4
    1
    i checked and it's a 3 litre.
  10. peterjon1
    peterjon1 Well-Known Member
    Aug 14, 2004
    1,117
    80
    Hardest thing with a 3.0 is keeping the oil on the inside of the engine:D. Also the timing belt/water pump change.
  11. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    9,505
    15,003
