AF: General electrical questions for 91 Imp | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by MrChrysler, Apr 13, 2020.
  1. MrChrysler
    MrChrysler New Member
    Dec 31, 2018
    12
    1
    Been having some odd issues that almost seems like its creeping around the car, its my rear windows and my automatic trunk lid pulldown that are inoperable. I've took the time to replace the switch and motor for my trunk pulldown which does indeed work when electricity is applied from an external source but whenever it is wired to the car is heats up like a frying pan and ceases to operate normally. Same goes for my rear windows and I am trying to figure out what there is to be done, any help is appreciated
  2. valiant67
    valiant67 ...
    36,305
    18,770
    I the motor is getting hot, it would seem that power is constantly applied to the motor when it should be cut off
    The service manual is available on line:
    Power locks and trunk pull down:
    http://oskin.ru/pub/chrysler-dodge/...nasty_LeBaron_Shadow_FifthAvenue/92FWD_8P.PDF
    Power windows:
    http://oskin.ru/pub/chrysler-dodge/...nasty_LeBaron_Shadow_FifthAvenue/92FWD_8S.PDF
    General wiring diagrams:
    http://oskin.ru/pub/chrysler-dodge/...nasty_LeBaron_Shadow_FifthAvenue/92FWD_8W.PDF
    My worry would be if these circuits run through the body computer then that may be the problem.
  3. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    7,840
    955
    Stupid question, I'm sure, but are you using the same gauge wire? If you're using too small of a gauge, it will, indeed, heat things up. It might even melt the insulation if you don't disconnect it.
