Heater valve - did i have it ?
Discussion in 'L: Horizon/Omni, Rampage, etc' started by torgtoe, Apr 13, 2015.
  1. torgtoe
    torgtoe Active Member
    Sep 12, 2006
    644
    7
    So im finishing my overhaul job soon, and i have started mounting cooling.
    The stupid thing i did, i didnt take Pictures and i threw all broken hoses and parts, - this was 2 years ago.
    Now i dont even cant remember if i ever had a heater valve.
    This is a 1982 Dodge Omni 024, 2.2 carbed.
    I noticed that rock auto sells one for 1982, but i cant see how this witl fit, as my waterpump only has one outlet -for the radiator.
    18,344
    2,704
    Normally, coolant always circulates through the heater core. The temperature blend air door chooses hot, cold or mixed air.
    An exception would be A/C cars where a water valve shuts off heater core coolant flow in the MAX A/C position only.
    It isn't particularly necessary in temperate climates.
    John Wood likes this.
  3. floridaman2013
    floridaman2013 Active Member
    Oct 17, 2013
    1,113
    322
    Don't have a SM, but if you have AC you should some type of shut off valave. Non-AC equipped cars didn't have one as far as I can remember back then.
  4. torgtoe
    Sep 12, 2006
    644
    7
    Thanks for answers guys . So - as i dont have A/C i understand i dont Mount the valve?
  5. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
  6. torgtoe
    Sep 12, 2006
    644
    7
    So i know you have Daytonas Bob, and so do i.
    I have deleted A/C on my turbo Z. Do you think i could delete the heater valve -just to prevent water leaks an clean up engine bay?
  7. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    Absolutely. The heater valve was only to block coolant flow through the heater core for air-conditioned cars, so that the A/C would not have to work as hard in the maximum setting.
    floridaman2013 likes this.
  8. turboomni
    turboomni New Member
    Jun 22, 2016
    6
    2
    If you have heat coming into the passenger compartment when you don't want to and do not want to pull the dash to fix it you can add a manual heater control valve. On my 86 Omni Glhs I wanted a larger radiator but didnt want to cut her up to do so ,so I rigged up a heater core from another car up front and routed the lines from the heater core to the new up front heater core with a manual heater control valve.
