AF: Help i need a hand | Allpar Forums
Help i need a hand
Discussion in 'Repairs, Maintenance, Help' started by Jeremy L Ferguson, Dec 2, 2019.
  1. Jeremy L Ferguson
    Dec 2, 2019
    1
    I have a 2003 chrysler pt cruiser 2.4 tubo had to put in a new lower thermostat housing car was running fine steaming cause that part had a leak cause somone broke a bolt in it before i got it but got it all done now its throwing p0700 and p0562 my battery did die while i was working on it due to the fact my key comes out when it on bad ignition or loose howerver you wanna put it had someone jump me wouldnt start even when somone was jumping me i am using tha acctual battery terminals not the ports now im charging the battery i erease the codes and it still wont start
  2. valiant67
    valiant67 ...
    35,490
    17,320
    When you say it won’t start, is the starter turning the engine over? If the starter is working, have you checked for spark and fuel pressure?
  3. DC-93
    DC-93 Well-Known Member
    May 1, 2014
    2,619
    1,423
    Some of the missing periods.
  4. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    7,537
    698
    You have several ground wires on the inside of the driver side fender. Remove the air filter box and you'll see them. You have to make sure they're clean and tight. This is a known problem area for the PT's.
  5. 06PTElectricBlue
    Apr 2, 2019
    154
    92
    Not to make fun of someone, or make light of the situation, when someone may be in a hurry or in a bind, but where would you like to put those periods, and have you included the correct #?! ;):cool::)
    DC-93 likes this.
