Help on rear end
Discussion in 'F-J-M: Volare, Diplomat, etc, 1977-89' started by Rogue, Jul 13, 2016.
  1. Rogue
    Rogue New Member
    Jul 13, 2016
    4
    ok so I have these to casting numbers
    2723676
    23258
    Ok it's a 7.25 rear end and it's got 2.76 in it I'm just curious if it's the original rear end
    It's 77 Plymouth Volare with a new high compression 360
  2. valiant67
    31,680
    10,954
    What was the original engine?
    The 7.25" rear axle is weak and only found behind the slant 6 and some 318s.
  3. Rogue
    Rogue New Member
    Jul 13, 2016
    4
    It was a slant 6 it's got them low gears so I kept it for gas mileage reasons
  4. valiant67
    31,680
    10,954
    The 2.7 ratio was standard with the slant 6 and an automatic transmission.
    you should be able to find a much stronger 8.25" axle or even an older B body 8.75" axle when the 7.25" axle breaks (which it almost certainly will behind the 360). Finding economy rated gears like 2.7 (or the common 2.2 used in later 8.25" axles) should not be hard.
  5. ImperialCrown
    18,231
    2,660
    Is there anything currently wrong with it now? Noisy?
    If you want to try and get maximum life from the 7.25" differential gears/bearings, change the hypoid oil to a 75W-140 synthetic hypoid lube:
    Drive the 360 gently as the 7.25" isn't made for the torque of this engine.
  6. gary longo
    gary longo Active Member
    Aug 17, 2014
    45
    37
    I had an 77 Aspen that had a 318, that I swapped a 360 into it....it had the 8 1/4" rear end in it,that held up to the motor pretty good. I had a .455 lift cam in it,so the motor had some grunt. So if the motor Isn't too radical...this should work for you. Otherwise look for a late 60's b-body 8 3/4" rear end :)
  7. Rogue
    Rogue New Member
    Jul 13, 2016
    4
    I have done reading and I've seen that about 500hp is most you've wanted to put on a 7 1/4
    I'm sure my engine doesn't make that, if it is I'd be surprised like crazy, and yes I'm currently looking for a bigger rear end, and the rear end is quiet and seems fine I believe we changed the fluid in it when we did the engine change witch wasn't that long ago
  8. Rogue
    Rogue New Member
    Jul 13, 2016
    4
    And my dad (we're both MOPAR guys) has a 65 valant and it has a upgraded 318 with some nice heads and intake and he runs a 7 1/4 in it o think it had 3.23
    Put that things had a lot of abuse and is still perfect
  9. valiant67
    31,680
    10,954
    It's your money, but there is no way the 7.25" rear axle is good for 500 HP. A stock slant 6 with all of 90-95 HP will kill one.
    Adventurer55 and hemirunner426 like this.
  10. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,593
    358
    Been putting 300 HP from my modified 318 through a 7.25 for 15 years now. No problems. Got the 8.75 for when it breaks.
  11. floridaman2013
    floridaman2013 Active Member
    Oct 17, 2013
    1,113
    320
    Wow, it's 2 of these and 2 of those! I've repaired a few 7.25 rears, mainly spider gears. They are alright to a point! Take care of it and don't shift gears in snow or mud too fast and you should do alright for while. Look for a larger one though for security in the long run.
  12. 2012srtchallenger
    Supporter
    Jan 27, 2013
    92
    60
    had 77 aspen r/t, shoe horned 440 ,4 spd and 9.25 out of 77coronet police car. the 8.25 didn't break but swapped 9.25 to be sure.just had to relocate spring perches but fit in body fine.i agree you would have to be very careful with 7.25
  13. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,593
    358
    I haven't been careful....
  14. pt006
    pt006 Active Member
    Dec 24, 2014
    1,284
    491
    Just lucky!!!
    I've changed out [2] 7.25's rear ends. Both were small blocks. Both were severely abused. Both had blown up spider gears which got in between the ring and pinion gears. Need I say what else went wrong?
  15. floridaman2013
    Oct 17, 2013
    1,113
    320
    Been there, done that!That's why we advise what to do is change it to a better Rear!
