AF: Hennessey To Build A Hellephant-Power Ram TRX 6×6? | Allpar Forums
Discussion in 'Mopar / FCA News' started by redriderbob, Sep 1, 2020.
  1. redriderbob
    redriderbob Mopar Guru!
    Supporter
    Feb 22, 2004
    12,765
    23,203
  2. patfromigh
    patfromigh Well-Known Member
    Jan 22, 2010
    3,549
    3,256
    "If more is better, too much is just enough."
    Shane Estabrooks likes this.
  3. tomaz
    tomaz Well-Known Member
    May 13, 2010
    2,054
    1,021
    Can the 1500 be stretched that long???!!!
  4. AC TC
    AC TC Well-Known Member
    Dec 3, 2004
    2,880
    568
  5. Shane Estabrooks
    Dec 9, 2014
    1,000
    761
    more then likely use a 2500/3500 frame.. but no matter what, the dual axle set up will take a lot of customizing
  6. CherokeeVision
    Dec 9, 2004
    5,936
    2,864
    If Bob Sheaves was still active here he would explain all the negatives of such a design.
  7. IronMike3406
    IronMike3406 Well-Known Member
    Jun 9, 2012
    248
    398
    I can tell you right now that the Rear suspension travel went from 13 inches to about 6 inches he's done a couple Chevy's and Ford Raptors with this same exact suspension setup.
  8. MoparMantis
    MoparMantis Well-Known Member
    Nov 26, 2004
    482
    193
    Make the rear axles dual wheel. 10x10 drive. The pickup is crazy already. Might as well dial it up one more notch.
  9. AC TC
    Dec 3, 2004
    2,880
    568
    It was called TRex, now its TRX.
    - any way, if Ram really whants to stand out in the pickup field it may be time to offer an Ram (x)500 BOOGIE
