Hi Guys! have a 72 dodge sportsman motorhome, small block, at,4bbl, headers etc
Discussion in 'Pre-1994 trucks, commercial vehicles' started by ROARR, Sep 2, 2017.
  1. ROARR
    ROARR Member
    Sep 2, 2017
    1
    It's stripped out and I've fabricated a drop down rear door/wall so I can load small cars and other stuff into it!
    where can I look for a color code of the wiring to the back? I find yellow, green, blue, black, brown, red, and white. I think the yellow and green are the right and left turn sigs, is there a stop circuit?,
    another question: on the top of the tranny (727?) in my Dakota OD tranny there's a plug, is that the start in neutral/ park switch?
    Thanks
    ROAR
  2. pt006
    pt006 Active Member
    Dec 24, 2014
    1,289
    493
    A test light is your friend.
  3. ImperialCrown
    18,233
    2,660
    Welcome to Allpar. The Reverse/Neutral safety switch should have 3 wires (VT, Wt and Br?) and is located by the rear ATF cooler line.
    If the rear half of the chassis isn't 'Chrysler', then I would not know what wiring color codes would be used. Unless you can find a manufacturer's upfitter shop manual, you may have to trace the wiring.
    pt006 likes this.
  4. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,557
    79
    Y = brake
    Brown = LH signal
    Green = RH signal
    White = ground
    IIRC
  5. pt006
    pt006 Active Member
    Dec 24, 2014
    1,289
    493
    One wire for the left signal; right signal; back-up lights; and parking/license plate/side lamps. Possibly one for ground for a fiberglass body.
    The brake lights are controlled by the signal switch on the steering column.
