AF: High beams only | Allpar Forums
High beams only
Discussion in 'EEK! - Every Extended-K Car' started by willrappold, Oct 12, 2016.
  1. willrappold
    willrappold Active Member
    Jan 23, 2013
    57
    3
    I have an 85 reliant se 2.2 L (TBI) and i have high beams only, when i push the toggle back nothing happens, is there a relay anywhere?, i used to here something click when it switched from low to high or vise-versa, now nothing. my turn signals, flashers still work. with the lights off you can still push back on the toggle and it will still flash the high beams.
  2. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    14,573
    4,055
    Have you confirmed the low beams are good? It's rare to have both fail at the same time, but you never know. It can happen.
    Sounds like a bad multi switch (stalk).
    ka9yhd likes this.
  3. valiant67
    valiant67 ...
    36,781
    19,594
    There is usually a rod from the stalk to a switch on the bottom of the column. The switch is probably what you heard operating. I've had the rod get out of whack. See if you can find the actual switch and push the button on it to get low beams. Then you'll know if the problem is the switch or the mechanism that triggers the switch.
    PCRMike likes this.
  4. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,579
    1,159
    Here is a link to selected pages from the 1984 factory service manual for front wheel drive Chrysler vehicles. I would expect the schematics to be the same for 1985 model year cars.
    There is a description for conducting an electrical test on the high - low dimmer switch. As Valiant67 indicated it is down low on the steering column and is actuated by a rod. The switch position is adjustable. The other schematics show wiring at the headlamp switch and connecting to the dimmer switch and onto the front headlamps.
    If adjusting the dimmer switch does not solve the problem, use a volt-ohm meter and check for voltage at the light green wire at the dimmer switch. It should have 12 volts with the headlamp switch turned on to headlamp position. The violet wire at the dimmer switch should have 12 volts when the dimmer is in low beam position. Hope this helps.
    Dropbox - K Car 1984
    #4 AllanC, Oct 12, 2016
  5. ka9yhd
    ka9yhd Well-Known Member
    Aug 17, 2013
    1,323
    275
    It can happen that both lamps are burnt out. A friend bought a used 1987 Omni. While driving the car on the test drive before buying it, he happened to click on the high beams and nothing. Only the low beams worked. Once he got the car home he did some checking and it turns out both high beam lamps were burnt out.
    I would check for 12 volts at the lamps first.
  6. willrappold
    Jan 23, 2013
    57
    3
    I think I found the problem when I took the cover off ( where fuses are located) to see the dimmer switch, I found it in pieces, the rod had fell out the steering column and the springs flew out, the green plastic cover had failed, also the contacts in my headlight relay are coming apart as well, so i'm gonna replace both, thanks for the help so far.
    ka9yhd likes this.
  7. willrappold
    Jan 23, 2013
    57
    3
    Does anybody have a diagram for how this dimmer switch/ rod is put together? Whatever the other end of the rod that goes into steering column is broke as well, so it falls back out. I guess ill have to find another steering column somwhere.
  8. ImperialCrown
    ImperialCrown Moderator
    21,265
    4,457
