How important is that timing belt tool?
Discussion in 'EEK! - Every Extended-K Car' started by Dodgem's Dad, Dec 7, 2017.
  1. Dodgem's Dad
    Dodgem's Dad Member
    Sep 12, 2017
    19
    4
    It looks to me like a wrench with a weight on one one. Couldn't I just add a similar weight to an open end or box wrench? Is this significantly better than the 90 degree twist method? I looked over the posts here and so far I haven't come to any clear cut opinion to sway me one way or another.
    The last work I did like this was on a 1928 Durant where the timing chain tension was adjusted by a pivot on the generator. I just pried until it sang its sweet song and then backed off a bit.
    Thank you all.
    Again.
    And again...
  2. Bob Lincoln
    Jul 10, 2002
    29,875
    3,255
    Never had a problem with the 90 degree twist method.
  3. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,557
    79
    I was told to use a10" thumb wrench.
  4. ImperialCrown
    18,231
    2,660
  5. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,390
    372
    In my experience, if the belt is centered on the sprocket after running the tension is just right.
    Thanks
    Randy
    Bob Lincoln likes this.
  6. Duner
    Duner Active Member
    Oct 28, 2003
    36
    1
    Have not had any problems using the 90 degree twist method on my 85 2.2.
  7. Rickorino
    Rickorino Well-Known Member
    Jan 23, 2005
    734
    128
    Used belt twist method too. The belt is better to be "slightly" loose then too tight.
  8. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    267
    172
    All the 2.2 timing belts I've done were on my non-AC L-bodies. I never bothered with messing with the alternator bracket/adjustment. I just popped off the crank pulley, swapped the belt. Putting it back, I'd get one crank pulley bolt started then roll the engine and start the rest of the bolts as they lined up. I hated the alternator belt adjustment on L-bodies.
    I have one of those 2.2 belt tension adjustment tools. If you decide you want one, shoot me an offer.
