How to adjust lower limit of window travel on '78 D-series truck?
Discussion in 'Ram, pickups, commercial trucks' started by 52Dodgecoronet, Oct 1, 2017.
  1. 52Dodgecoronet
    52Dodgecoronet Active Member
    Feb 25, 2010
    128
    15
  2. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,495
    430
    I don't have experience on this model but in the past I have found that a lot of windows had a metal plate with a rubber grommet over it. They would eventually break and fall off. Pull the inner panel and look. Should be evident by lowering the window.
