Hurricane Torque - Can you guess the ft-lbs?
Discussion in 'Mopar News' started by redriderbob, Oct 19, 2017.
What’s the Hurricane’s torque?
Poll closed Oct 22, 2017.
  1. 260-265 ft-lbs
    3.8%
  2. 265-270 ft-lbs
    3.8%
  3. 275-280 ft-lbs
    2.5%
  4. 280-285 ft-lbs
    5.0%
  5. 285-290 ft-lbs
    11.3%
  6. 295-300 ft-lbs
    23.8%
  7. 300-305 ft-lbs
    5.0%
  8. 305-310 ft-lbs
    15.0%
  9. 310-315 ft-lbs
    11.3%
  10. 315-320 ft-lbs
    18.8%
  1. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    9,472
    14,946
    Wow, one of your numbers is right, the other is way off.
    Tomguy likes this.
  2. Tomguy
    Oct 4, 2011
    1,028
    616
    Too high on the torque? I was afraid of that. Probably closer to 276 or so then.
  3. KrisW
    KrisW Active Member
    Jan 8, 2015
    1,115
    1,894
    Torque 400, power 200. I've never been much taken to talk about feet, or pounds, or the sweat of horses when it comes to engineering...
    MOPARTE likes this.
  4. scatpack_69
    scatpack_69 Active Member
    Feb 5, 2013
    168
    166
    I voted the highest, but that's lower than the ~350ft-lbs I figured.
  5. WXman
    WXman Active Member
    Oct 28, 2014
    597
    526
    I voted 295-300 because that's a nice number for advertisting purposes and gives them room to grow.
    UN4GTBL likes this.
  6. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,608
    2,801
    400 Nm (ECE, SAE is higher) from engine and 20 Nm from electric motor of the BSG system.
    Potentially they could go up with the electric motor, in similar BSG the commercial proposition of suppliers is up to 150 Nm from electric motor, but for reliability, costs and margin to increase performances over years I suppose they wil start òpw with electric motor contribution.
    So 317 lb ft (430 Nm).
    The limit is anyway the 500 Nm of the gearbox used in the new Wrangler.
    xjgary likes this.
  7. redriderbob
    Feb 22, 2004
    9,472
    14,946
    Nope, less than 317 lb ft
  8. redriderbob
    Feb 22, 2004
    9,472
    14,946
    I will give you one more clue... 287 and that isn't the torque number.
  9. chcg12
    chcg12 Member
    Jan 3, 2013
    38
    14
    so..its 287hp and 310tq
  10. redriderbob
    Feb 22, 2004
    9,472
    14,946
    No.
  11. Max Wedge
    Max Wedge Active Member
    Oct 18, 2013
    863
    369
    268 HP 310 Torque.
  12. redriderbob
    Feb 22, 2004
    9,472
    14,946
    Not quite.
  13. AlfaCuda
    AlfaCuda Active Member
    May 18, 2012
    702
    601
  14. Tomguy
    Oct 4, 2011
    1,028
    616
    268 HP, 277 ft-lbs, that's my final guess.
  15. redriderbob
    Feb 22, 2004
    9,472
    14,946
    Your final guess is wrong.
  16. Tomguy
    Oct 4, 2011
    1,028
    616
    I am sure, but it'd be nice to know how close or far away it might be :p
  17. redriderbob
    Feb 22, 2004
    9,472
    14,946
    Not very.
    wilbur likes this.
  18. redriderbob
    Feb 22, 2004
    9,472
    14,946
  19. mentalicca
    Aug 14, 2009
    1,025
    770
    F4U Corsair, eh. We suggesting that the horsepower number is 280? As a reference to the 2800 engine?
    xjgary and ScramFan like this.
  20. redriderbob
    Feb 22, 2004
    9,472
    14,946
    Not exactly but you are on the right track!
