Hurricane Torque - Can you guess the ft-lbs?
Discussion in 'Mopar News' started by redriderbob, Oct 19, 2017.
What’s the Hurricane’s torque?
Poll closed Oct 22, 2017.
  1. 260-265 ft-lbs
    3.8%
  2. 265-270 ft-lbs
    3.8%
  3. 275-280 ft-lbs
    2.5%
  4. 280-285 ft-lbs
    5.0%
  5. 285-290 ft-lbs
    11.3%
  6. 295-300 ft-lbs
    23.8%
  7. 300-305 ft-lbs
    5.0%
  8. 305-310 ft-lbs
    15.0%
  9. 310-315 ft-lbs
    11.3%
  10. 315-320 ft-lbs
    18.8%
  1. Detonator Yellow
    Detonator Yellow Active Member
    Mar 26, 2012
    245
    33
    292 HP and 295 pounds of twist?
  2. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    9,355
    14,692
    Not quite.
  3. Detonator Yellow
    Mar 26, 2012
    245
    33
    280, 282, 284 and 292-297?
    That's all I have
    #63 Detonator Yellow, Oct 25, 2017
  4. mopar22
    mopar22 Well-Known Member
    Sep 22, 2010
    1,164
    377
    Believe the torque will be above 300 with the hp being in the 260s
  5. Tomguy
    Oct 4, 2011
    1,024
    614
    If I made another guess, that would have been it, too.
  6. redriderbob
    Feb 22, 2004
    9,355
    14,692
    [​IMG]
  7. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    4,406
    5,091
    This thread has been the best meme generator Allpar has had in a long time.:D
    suzq044 likes this.
  8. djsamuel
    Sep 10, 2007
    2,665
    394
    You must be LOVING this!
  9. jam1
    jam1 Active Member
    Feb 25, 2012
    532
    393
    294-H.P. and 305-torque. I LOVE this! And, in any case, this is going to be one more powerful engine!!
  10. redriderbob
    Feb 22, 2004
    9,355
    14,692
    Just a bit... but your numbers are wrong.
  11. mopar22
    Sep 22, 2010
    1,164
    377
    268 and 315
  12. eggwhite93
    eggwhite93 Active Member
    Sep 27, 2017
    48
    63
    I think the answer has already been given in the form of not giving a direct answer.
    268 hp and 295 tq
    redriderbob and Tomguy like this.
  13. humdrum
    humdrum Well-Known Member
    Nov 4, 2010
    792
    679
    I'm curious, what is the weight difference between the 3.2 and the Hurricane turbo? Is it approximately the same or is there a significant difference that could affect the performance of, say the 2019 Cherokee? I would imagine that the HP and Torque are similar.
  14. link3721
    Oct 18, 2012
    918
    609
    Hp similar, Hurricane torque is much better.
  15. Tomguy
    Oct 4, 2011
    1,024
    614
    I didn't want to guess because I felt it would have been unfair, after I was shot down enough times I narrowed it down enough, and that was literally going to be my next guess.
    I just wanted someone else to have it :)
    Think about it this way. 268 is the power number. It was all but literally confirmed when I was told one of my numbers was way off, and I saw way off for other people guessing torque around that number (310).
    I also saw a post saying HP was even and torque was odd. So that was my reason for my guess right before the 268/295, when I went to the opposite end (the low end) of the hint, and said 268 HP, 277 ft-lbs, that's my final guess.
    My other guess would have been 295 because if it was 297 I really think they would have rounded up to 300, but 295 is still "Far enough" away to not say 300.
    xjgary and redriderbob like this.
  16. DarkSky
    DarkSky Moderator
    Jan 29, 2016
    1,823
    2,566
    Nobody is really taking the time to figure out which engine is in the first post. That gives away the torque number.
  17. moparfan06
    moparfan06 Active Member
    Sep 24, 2013
    106
    30
    That hint helps. I know the answer! Is it OK to share it?
    DarkSky likes this.
  18. DarkSky
    DarkSky Moderator
    Jan 29, 2016
    1,823
    2,566
    Some people have already figured out the torque in the other thread.
  19. GasAxe
    May 12, 2008
    4,406
    5,091
    And to close things here, 295lb-ft is the winner.
    suzq044 likes this.
