AF: HVAC not coming out of the right vents | Allpar Forums
Discussion in 'Minivans · Pacifica' started by thedriver, Jan 17, 2015.
  1. thedriver
    thedriver Active Member
    Feb 10, 2006
    256
    16
    My HVAC will only blow out of the dash front and defrost positions at all times. Turning the knob makes no difference. I have done the recalibration, but it ends up with the RR defogger blinking. Next step?
    ImperialCrown Moderator
    21,008
    4,222
    Is this a 2006 MTC system? Does the recal procedure change the air blowing out the floor, vent and defroster positions (mode door test)? Does it also change the air temperature (blend door test)?
    The 'self-test' given here: http://www.allpar.com/fix/codes-climate.html may not work on the newer RS minivans and a capable scan tool may be needed to get BCM/HVAC fault codes and run calibration/diagnostics.
    See SYSTEM DIAGNOSTICS starting on p. 20 of the Body Diagnostic Procedures manual:
    http://oskin.ru/pub/chrysler-dodge/manuals/Service Manuals/2005_RS_Caravan_Voyager/2005-RS-Body.pdf
    It may be a stuck door or servo/stepper motor or linkage. Does anything move on the drivers side of the HVAC housing when you select a different mode or do you hear any 'clicking'?
  3. thedriver
    Feb 10, 2006
    256
    16
    during the recalibration you can hear the doors moving. afterwards there is no change.
  4. ImperialCrown
    21,008
    4,222
    Is this a 2006 dual-zone MTC system?
    Calibration can improve HVAC volume and temperature performance, but it usually doesn't 'fix' door actuation problems. The quickest diagnosis is by scan tool (DRB III or equivalent).
    It sounds like a mode/distribution door is stuck or an actuator (servo) is not moving.
    You should be able to watch the mode/distribution linkage move under the drivers side of the dash with the ignition on and by selecting floor, panel or defrost. Watch for what isn't moving.
    http://ww2.justanswer.com/uploads/dodgetech77/2012-04-01_022026_ns_ac_blend_door.gif
  5. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    34,733
    20,190
    Just as a quick anecdote… anyone else remember vacuum actuated doors? Slam on the gas and the vents would change, if you had a bad vacuum reservoir. I think a lot of them came out of the factory nonfunctional...
    Ray Green likes this.
  6. thedriver
    Feb 10, 2006
    256
    16
    single zone base model T and C.
  7. gusc
    gusc Member
    Dec 8, 2004
    517
    39
    My '94 pickup did this when rats ate the vac line for the system. All I had was defrost and panel in any mode.
    Don't think this applies to late models though.
  8. ka9yhd
    ka9yhd Well-Known Member
    Aug 17, 2013
    1,313
    271
    Default is defrost mode. Might be a vacuum leak.
  9. ImperialCrown
    21,008
    4,222
    No vacuum actuators, these doors are all controlled by electrical stepper motors with door position feedback to the BCM.
