I never thought I would own a truck that....
Discussion in 'Dakota, 1998-2013 Durango and Aspen' started by Peymack91, Oct 23, 2016.
  1. Meester Beeg
    Meester Beeg Active Member
    Sep 10, 2016
    140
    45
    There should be a bracket with the timing marks on the front of the engine and a notch in the balancer. Set timing as you would a points dizzy except disconnect the engine temp sensor on the R side of the t stat with engine at operating temp.
  2. Peymack91
    Peymack91 Member
    Aug 17, 2016
    42
    I will do this tomorrow and get back with results. Thanks!
  3. Peymack91
    Peymack91 Member
    Aug 17, 2016
    42
    Timing was set at 0 TDC. No wonder it's gutless.
  4. Meester Beeg
    Sep 10, 2016
    140
    45
    And it's supposed to be...?
    Bob Lincoln likes this.
  5. pt006
    pt006 Active Member
    Dec 24, 2014
    1,281
    490
    For a full size truck a few years older the spec is 10 degrees BTDC.
  6. Bob Lincoln
    Jul 10, 2002
    29,873
    3,257
    Doesn't matter, can change from year to year. Need the spec for that vehicle, that year.
  7. Meester Beeg
    Sep 10, 2016
    140
    45
    IIRC the spec is 10 BTDC.
