Idle Speed
Discussion in 'Dakota, 1998-2013 Durango and Aspen' started by Glopart, Aug 15, 2016.
  1. Glopart
    Glopart Active Member
    Feb 26, 2006
    76
    9
    I have a 2006 4.7 HO, 5 sp auto, 4X4 Dakota with about 76k miles. Recently, even with the hot weather, I've noticed the idle speed surging when first started on a cold start. I say cold start but it's actually about 75 deg. ambient or higher. The idle speed will surge to about 1500 RPM down to 700 or 800 then back up and back down about 3 or 4 times before settling in at what looks like about 700. Once I put it in gear and drive off everything is fine. Subsequent warm engine starts through the day are fine.
    Is this a sign of something or not a concern?
    No codes and the truck runs like a top.
    18,231
    2,660
    Does the A/C work? Can you hear the click of the compressor engaging? If you turn the A/C completely off, does it still surge?
    Has the throttle body blades and bores been cleaned recently?
  3. Glopart
    Feb 26, 2006
    76
    9
    The AC does work but I'm not sure whether it's been on or off during the surge. I'll try it and see.
    I also thought about the throttle body since I've NEVER cleaned it. Do you recommend a particular brand
    of cleaner?
  4. ka9yhd
    ka9yhd Active Member
    Aug 17, 2013
    1,151
    219
    Throttle body cleaner not carb cleaner.
    You can use an old tooth brush to scrub the bore and the edges of the throttle plate. Spray the cleaner through the bypass port for the AIS. Also remove any vacuum hoses from the throttle body and spray the cleaner through the vacuum passages.
  5. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,524
    240
    Also check the wires sensor for any fraying. If you see any, cut off the offending piece and splice the ends together.
  6. Glopart
    Feb 26, 2006
    76
    9
    Finally got around to cleaning the throttle body as described above. Been a little busy. Looked at sensor wires but didn't see any damage.
    Surging problem seems to be gone. AND, if possible, the off idle and part throttle response seems better. Might just be my imagination though.
    Thanks for the tips.
