Intake Manifold
Discussion in 'Non-Mopar Tech Support' started by Rickorino, Aug 25, 2016.
  1. Rickorino
    Rickorino Well-Known Member
    Jan 23, 2005
    734
    128
    I didn't know if I should start a new thread on this regarding my aluminum lower intake manifold on my Buick 3800 engine. Checking flatness, what is generally the maximum allowable gaps when checking for warpage? I am measuring .005 gaps in some areas on one bank which meets up on the head. The other is much less in the .003 range in a couple areas. I am using a precision straight edge over the whole length and a feeler gauge. I would appreciate any comments/ experiences.
    #1 Rickorino, Aug 25, 2016
  2. pt006
    pt006 Active Member
    Dec 24, 2014
    1,284
    491
    Rick; Run it! The gasket will squash more than that.
    dana44 likes this.
  3. Rickorino
    Jan 23, 2005
    734
    128
    Thanks for responding, I will run with it.
