JEEP AUTOMOTIVE ENGINEERS - Need help in locating software
Discussion in 'Wrangler, CJ, Wagoneer, other traditional Jeeps' started by Hemidakota, Jun 1, 2017.
  1. Hemidakota
    Hemidakota Active Member
    Jan 24, 2017
    596
    367
    I have a heavy, modified tactical off-road vehicle, with significant changes to the Center of Gravity (CG) and weight from the original engineering data sheet. Is there a free online/website calculator/tool that can be used to calculate a vehicle's risk of rollover (or provides estimates of limits) based on factors such as:
    - CG
    - CG height over ground
    - Vehicle weight (variable based on passenger load)
    - Axle separation
    - Speed
    - Acceleration/deceleration
    - Surface type (asphalt, loose dirt, packed dirt)
    - ascent/descent/side slope grades
    18,229
    2,657
    Good question. A 'risk of rollover' app would have liabilities, whether or not something went wrong. I know of no engineer who would put their reputation on the line as to any vehicle's ultimate 'tipping point'.
    A mechanical engineer may have some pointers and there is some 'common sense' guidelines. There are likely a few more variables and possible unknowns to the equation than you stated.
    Bob Lincoln likes this.
  3. ptschett
    ptschett Well-Known Member
    Dec 30, 2004
    812
    112
    We actually do publish tipping loads in my line of work (construction equipment), the rated operating load of a wheel loader, tractor-loader-backhoe or skid-steer loader is generally 50% of the load that makes the machine tip forward.
    The calculators that I know of are proprietary since they need to account for the kinematics of the lift arm linkages.
    ImperialCrown likes this.
