Jeep Cherokee refresh: styling direction?
Discussion in 'Mopar News' started by oh2o, Jun 4, 2016.
  1. james.mooney.
    james.mooney. The Poster Formerly Known As "Bethlumboy"
    Feb 10, 2007
    2,594
    1,381
    Has anyone heard any possibility of the Cherokee getting the Pacifica's PHEV system? It seems like the next logical application, other than a Chrysler CUV ("RA" or KL-based).
    If they do a Cherokee PHEV, would it make more sense to use the 3.6 V6, or to adapt it to work with the Tigershark or Hurricane 4 (since it is a smaller vehicle)?
  2. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    10,586
    17,766
    The DRL's on the 2018 Cherokee retain the same shape. The hi/low beam projector is moved up to the same housing as the DRLs. The projector's are moved to the outside of the lamp. Where the headlight is in the current Cherokee is replaced with a turn signal. The fog light's stay in the same spot however become like the Chargers three led layout. Turn signals will also be LEDs.
  3. Erik Latranyi
    Aug 20, 2003
    11,054
    10,698
    Don't forget, this is a refresh, not an all-new model.
    The refresh is mostly cosmetic. The plant is retooled.
    Since most everything on the Cherokeee stays the same, it makes sense to start and build the old design so the equipment can be tweaked properly before starting on the new bodystyle.
    valiant67 and dakota21 like this.
  4. BobbiBigWheels
    BobbiBigWheels The "Front-Line" Perspective
    Jun 2, 2016
    2,825
    3,942
    I understood every part of your comment except the bolded part. What kind of shape does the headlight retain?
  5. freshforged
    freshforged Well-Known Member
    Dec 4, 2003
    2,234
    1,463
    Using the old model to troubleshoot the new line?
  6. UN4GTBL
    Jan 7, 2006
    8,146
    2,858
    More of a conventional headlight design/shape
  7. redriderbob
    Feb 22, 2004
    10,586
    17,766
    2018 Jeep Cherokee
      • Production startup August 28, 2017 (Belvidere plant)
      • Mid-cycle refresh, revised front design, changes to rear fascia
      • New 2.0L "Hurricane" engine (2018 or 2019 model year)
      • Supposedly 3.2L to be dropped for 3.6L engine.
  8. redriderbob
    Feb 22, 2004
    10,586
    17,766
    The projectors for the hi/lo beam is pushed to the outside corner of the headlights.
    BobbiBigWheels and UN4GTBL like this.
  9. redriderbob
    Feb 22, 2004
    10,586
    17,766
    Correct. Also Cherokee is the most sold Jeep. Have to keep dealers supplied.
    UN4GTBL likes this.
  10. oh2o
    May 19, 2001
    3,511
    3,971
    Roughly speaking, overall headlamp housing shape, current on top, new on bottom, see attached.
  11. UN4GTBL
    Jan 7, 2006
    8,146
    2,858
    Makes sense, as I would think that the hood and fenders would stay the same
  12. dakota21
    Supporter
    Jun 17, 2014
    247
    198
    That makes sense. As an industrial engineer (co-op), I can still see the changeover to the refresh being a potential headache after just setting up for the old equipment. But nothing can replace good troubleshooting in a new environment.
  13. Deckard_Cain
    Deckard_Cain Active Member
    Dec 20, 2016
    616
    960
    And when will they show the facelift to the public? Is there an ETA for that?
    From what oh2o has attached, the new headlights will be similar to the Compass headlights.
  14. Archknight
    Archknight Active Member
    Jan 29, 2012
    273
    192
    I'm looking forward to this, since I can't wait anymore on a new car and I was holding out to see what was coming out of Chrysler. I guess I'll have to settle for a 2018 Cherokee.:):):)
    cdjr77 likes this.
  15. oh2o
    May 19, 2001
    3,511
    3,971
    Quite different actually.
    AlfaCuda, Mike V. and dakota21 like this.
  16. dakota21
    Supporter
    Jun 17, 2014
    247
    198
    Good. That gives me hope that it won't be another GC variant.
  17. UN4GTBL
    Jan 7, 2006
    8,146
    2,858
    Yeah, from what I understand, it will retain it's "distinctive" look, but be a bit more "mainstream", while still not a GC clone like the Compass
    Prabhjot likes this.
  18. Archknight
    Jan 29, 2012
    273
    192
    Hopefully, they are doing a wheel package revamp as well. The Trailhawk's wheel design are the only ones I like so far and it would be nice if they could be had on other models.
    Another thing that I keep wondering is that because Keep is so popular right now, if those LWB Cherokees we saw will make it stateside? It's not like they wouldn't fly out of showrooms here and with the option of a 3rd row or more cargo space, it would make sense in the lineup until the Wagoneer models arrive.
  19. Mike V.
    Jan 24, 2008
    24,858
    18,701
    I already said it wasn't ;)
    Mike
    Archknight, dakota21 and Alexbucks like this.
  20. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,758
    3,053
    From this video one can see what the front plastic fascia overs and the how lamp assemblies are attached. What FCA could modify is the front fascia and shape of lamps, they will not modify how are attached or the metal body panels.
    From minute 5 is when front fascia is pulled out.
    humdrum, james.mooney. and T_690 like this.
