AF: JGC won't start | Allpar Forums
JGC won't start
Discussion in 'Repairs, Maintenance, Help' started by Christopher, Sep 6, 2020.
  1. Christopher
    Christopher Socially Unacceptable
    Staff Member Level 2 Supporter
    Jul 8, 2002
    5,643
    2,132
    I have a 2012 JGC 5.7, 4WD.
    I backed it into the garage.
    I plugged my phone charger into the power outlet in the center console. It would not charge so I checked the fuse.
    The fuse was blown. When I put the new fuse in, it immediately blew. (I suspect that that car charger has gone bad.)
    I unplugged the phone charger and replaced the fuse. It did not blow.
    I went to move the Jeep out of the garage and it won't start. Nothing. I have power to the lights and I can open the rear hatch, but it doesn't even try to start.
    I cannot get to the battery to disconnect it, although I have started pulling fuses.
    It is currently partway in/out of the garage and I can't get it into neutral to push it in or out of the garage.
    Any thoughts?
    ImperialCrown Moderator
    21,271
    4,462
  3. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,580
    1,160
    Does your vehicle have remote start capability? If YES push the appropriate key fob button twice and determine if the starter will engage. The hood must be securely closed for the remote start capability to function. There must be do diagnostic trouble codes stored in the powertrain control module for remote start capability. If the starter will engage and the engine fires, then you know the problem lies with an invalid signal from the ignition key switch (hard wired) from the ignition switch to the TIPM (totally integrated power module).
    Here is a video that shows some troubleshooting techniques for a 2011 Jeep Grand Cherokee no start situation. Hopefully the layout in the fuse box - relay area is the same for your 2012 model.
    View: https://www.youtube.com/watch?v=EWL5UvEgSgw
  4. Christopher
    Jul 8, 2002
    5,643
    2,132
    Thank you all. The issue has been resolved.
  5. Gerry G
    Gerry G Well-Known Member
    Mar 7, 2003
    1,178
    194
    For the benefit of others, what was the resolution?
  6. Christopher
    Jul 8, 2002
    5,643
    2,132
    Regarding the blown fuse, I believe the phone charger is bad. It blew fuses in my Charger as well the day before and that was the common denominator. Other than my phone.
    That was unrelated to the No Start issue.
    That was User Error. It won't start if the key is on my desk. The key in my pocket was the key to the Charger.
    Too much stress trying to get ready to leave town for 3 months for a new job led me to being scatter brained. And then stressing out when it wouldn't start because I was behind schedule led me to not thinking clearly.
    So yeah....that happened. lol
    jerseyjoe and Doug D like this.
  7. Gerry G
    Mar 7, 2003
    1,178
    194
    can't say that has not happened to me.... recently
  8. chuzz
    chuzz Allpar Legacy
    Apr 3, 2004
    8,035
    1,106
    No matter the cause, you persevered and figured it out. THAT is what counts. Good for you.
    Christopher likes this.
  9. jerseyjoe
    jerseyjoe Plymouth Makes It
    Apr 13, 2002
    8,093
    2,190
    Wait till you hit 74....
