JL Wrangler shows up in dealer computers with features/options/packages
Discussion in 'Mopar News' started by kilgore, Aug 7, 2017.
  1. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,387
    15,054
    In any case, we’re still talking about something with more torque “where you need it” than the 3.8; and the eight speed takes care of a LOT of problems!!!!
    Not enough torque? Drop first gear! ;)
    Can someone review this for factual errors?
    The recent revelation that the next-generation, 2018 Jeep Wrangler JL will have an optional full-time all wheel drive system struck a nerve with some, who saw it as being inappropriate for the vehicle.
    In its “Rubicon-capable-only” days, Jeep sold CJs and Wranglers with rear wheel drive only; today, all Wranglers drive all four wheels. The current “JK” has part-time four wheel drive, which stays in rear wheel drive unless the driver pulls a lever to active the other wheels. That dramatically increases the turning radius and wears out the tires quickly, unless the Jeep is being driven on a “giving” surface.
    Most Wranglers are not taken off-road, though all are capable of tackling very serious trails (and land between trails). Even when Jeep was very much a niche brand, selling CJ, Cherokee, and Grand Cherokee, market research showed very few buyers took their new Jeeps on land that, say, an AWD Charger couldn’t handle. (CJs and Wranglers still dominate off-road meets, but that’s a fraction of the hundreds of thousands sold each year.)
    Most buyers want a vehicle that can handle bad weather, not large rocks. For that purpose, full-time all wheel drive is often a better choice. It can be left on at all times, doesn’t affect the turning radius, and cuts fuel usage by staying in RWD unless all wheels are needed. Part-time systems lock up the torque to front and rear at 50/50; there is no slipping in the transfer case, so it has to slip between the tire and road or ground, because tires turn at different speeds when making turns.
    Tailoring the vehicle to the actual buyer, rather than to the image, is likely the main reason why a full-time system is coming to Jeep — from appearances. It might be the same setup as the one used in the Grand Cherokee, or it might be similar to a past Jeep system which worked mechanically but allowed slip.
    According to reliable source oh2o, buyers of the Jeep Wrangler JL Sport and Sahara will have a choice between the Command-Trac part-time system and the Selec-Trac full-time system. All Rubicon buyers will get the Rock-Trac heavy duty full time system.
    The Rock-Trac, unique to the Rubicon, has a 4:1 ratio in low gear, for crawling very, very slowly, with a high level of control for the most demanding situations. The Selec-Trac has a 2.72:1 ratio, which is good enough for all common uses and serious off-roading as well. The current Command-Trac part-time 4x4 system also has a 2.72:1 ratio.
    According to Allpar source “Ruptured Duck,” ordering for the JL will start in October 2017, possibly only for the Unlimited, and definitely with the V6 engine only. The first Wrangler is slated to be built in November, two full weeks before the official reveal in Los Angeles.
    The first two-door Wranglers will start in February; while they are superior in tough off-road situations, they are far less convenient and sales of the four-door are much higher than sales of the two-door.
    The Wrangler JK is slated to leave production at the end of March 2018. The four-cylinder Hurricane engine is to become the base engine in mid-to-late 2018, while the VM diesel will become an option at that time. (The Rubicon may keep the gasoline V6 as its standard engine.)
    Export Wranglers are to get a 2.2 liter four-cylinder diesel.
    aldo90731, Zagnut27, wilbur and 2 others like this.
  2. Mike V.
    Jan 24, 2008
    24,871
    18,735
    @Dave Z completely agreed!
    Mike
  3. Ruptured Duck
    Ruptured Duck Active Member
    Jan 2, 2015
    878
    1,221
    @Dave Z I would only note that the info I got was from a dealer and I have no way to confirm if it was something they put together of if it really came from FCA.
    Just want to make that clear.
  4. Dave Z
    Jan 23, 2001
    32,387
    15,054
    OK - thanks.
  5. Mike V.
    Jan 24, 2008
    24,871
    18,735
    And the 2.2L Diesel is supplied by Fiat Powertrain. It is currently used in the export market KL Cherokee.
    Mike
  6. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,759
    3,054
    2.0 with or without BSG, that makes some difference since most BSG system are used also for their e-boost capability.
    How much weight is expected to decrease since use of aluminium doors, hood, ultra high strength and similar steels, plastic composites, ... ?
    xjgary likes this.
  7. Erik Latranyi
    Aug 20, 2003
    11,054
    10,699
    I predict weight will slightly increase.
    wilbur likes this.
  8. Mike V.
    Jan 24, 2008
    24,871
    18,735
    Agreed.
    Mike
  9. dmcdonald
    dmcdonald Active Member
    Jun 19, 2012
    872
    916
    Just a note, but the CJ was never available with the 4.0. The 4.0 debuted in '87 on the YJ, XJ and MJ. The CJ at the end of its run was still using the 4.2L, an engine high on torque but very low on HP. :oops:
    GasAxe, Erik Latranyi and xjgary like this.
  10. zack_falcon
    zack_falcon Active Member
    Feb 15, 2015
    209
    154
    Is it any good?
  11. Mike V.
    Jan 24, 2008
    24,871
    18,735
    I have never driven it. The Fiat fans all say good about it and Top Gear talked good about it.
    Mike
    #211 Mike V., Aug 15, 2017
    zack_falcon likes this.
  12. CherokeeVision
    Dec 9, 2004
    5,410
    2,093
    The AMC 304 V8 was offered in the CJ-7.
  13. Bionicrooster
    Bionicrooster Well-Known Member
    Jan 22, 2008
    198
    131
    not to nit pick, but the first few years of YJ used 4.2 (I had an 89 with the 4.2). I think the 4.0 appeared in or around 1991.
    GasAxe and Erik Latranyi like this.
  14. Dave Z
    Jan 23, 2001
    32,387
    15,054
    Good corrections.
    xjgary likes this.
  15. aldo90731
    Jul 6, 2010
    5,998
    9,971
    Thank you for the summary, Dave.
    The only thing I'd add is that the reappareance of Select-Trac strikes a positive chord if it represents a reintroduction of the prior full-time/part-time 4WD; but FCA's choice of name strikes a nerve if it represents an all-new electronic AWD system.
    If the latter, FCA could easily name it Select-Trac II. This is a practice Jeep has followed in past with both Quadra-Trac and Quadra-Drive to avoid confusion in the market.
    From my personal experience, FCA provides dealers very little information when ordering opens. I have been in situations where the dealer taking my order could not clarify for me what the difference was between the 430N and 730N radios, or the difference between "leather seats" and the "sound and leather package". These options are usually priced hundreds, sometimes thousands of dollars apart, and money adds up quickly.
    Wrangler buyers, especially those placing orders, know the difference between a 4.10 and a 3.73 gear ratio. I think FCA should be very clear with Select-Trac to avoid the ongoing confusion between an electronic AWD and a full-time 4WD.
    It becomes very expensive for a dealer to try to rectify an order, and difficult to retain a customer, once the vehicle arrives at the dealership with the incorrect equipment.
    #215 aldo90731, Aug 16, 2017
    guyverfanatic, JKU12 and Zagnut27 like this.
  16. Dave Z
    Jan 23, 2001
    32,387
    15,054
    Yes, I agree. I'll update it.
  17. dmcdonald
    Jun 19, 2012
    872
    916
    Yup...you are correct! Fingers worked faster than my brain. I had one too...lol.
    GasAxe and Bionicrooster like this.
  18. AutoTechnician
    Oct 13, 2012
    1,712
    1,195
    I've driven 4-cylinder YJ and TJs. They're completely acceptable, and have a worse power-to-weight ratio than the 3.8 JKs. A 200-250 hp or so 4 cylinder would be a perfectly fine base engine.
    I've see a 1.6L 90hp Suzuki Samurai turn giant 44" tires. It made it through a huge mud pit that blown V8 trucks were getting stuck in. The only thing that really matters off road is the gearing. The military's old 2.5 ton trucks only had 145 HP, in diesel or gas trim, and they worked fine off road. They weighed three times what a JK does.
  19. CherokeeVision
    Dec 9, 2004
    5,410
    2,093
    But how satisfactory would they be as a daily driver in lots of traffic?
    The Wrangler needs to live in both worlds.
    Mike V., dmcdonald and UN4GTBL like this.
  20. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    4,601
    5,512
    The 4 banger YJ's and TJ's were acceptable, but not very pleasurable and Jeep sells on pleasure. A turbo 4 will need to be tuned for low end torque and forgo the temptation to produce lofty horsepower numbers in the high rpm range. I'm not enthusiastic about the return of 4 cylinder engines in the Wrangler, but I think the Wrangler engineers can pull it off.
    UN4GTBL and Mike V. like this.
