JL Wrangler shows up in dealer computers with features/options/packages
Discussion in 'Mopar News' started by kilgore, Aug 7, 2017.
  1. Mike V.
    Jan 24, 2008
    24,880
    18,751
    Which is exactly what previous discussions have been about. If other FCA vehicles are criticized for not having enough power, the Wrangler will certainly be trounced for it.
    Norm was very critical of four cylinder powered Wrangler’s and he was right to do it.
    Mike
    Ruptured Duck likes this.
  2. CherokeeVision
    Dec 9, 2004
    5,411
    2,093
    When I look at missteps regarding Wrangler (2 wheel drive versions) I try to look at them in a positive light.
    They are a source of used parts to keep your Wrangler running.
    Four cylinder JL's might be the same way.
    LordHobbit and UN4GTBL like this.
  3. Mike V.
    Jan 24, 2008
    24,880
    18,751
    I do not have an issue with four cylinders. I have an issue with using an underpowered four cylinder whether it is gas or diesel.
    Nice job making lemonade though. :)
    Mike
    UN4GTBL and hemirunner426 like this.
  4. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,393
    15,056
    Eight speeds, no waiting... if you shift quickly enough.
    They had slant sixes in class 8 trucks.
    It's all in the tuning — and if it's a mild hybrid, that will get the engine up to speed while the turbo spools.
    Chrysler used to be known for its “no waiting” powertrains. They went away from that for a while but I can hope.
    guyverfanatic, UN4GTBL and Mike V. like this.
  5. Mike V.
    Jan 24, 2008
    24,880
    18,751
    The 8 speed is the key to the puzzle for sure.
    Mike
    guyverfanatic and dmcdonald like this.
  6. Dave Z
    Jan 23, 2001
    32,393
    15,056
    And a wide-ratio manual option.
    Mike V. likes this.
  7. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,759
    3,054
    With the second generation ZF 8HP there is a second gear set that is available.
    The new one is also used by Alfa Romeo Giulia and Stelvio.
    1 2 3 4 5 6 7 8 R
    4.714 3.143 2.106 1.667 1.285 1.000 0.839 0.667 3.300
    5.000 3.200 2.143 1.720 1.314 1.000 0.822 0.640 3.456
  8. AutoTechnician
    Oct 13, 2012
    1,712
    1,198
    A 4000 lb Wrangler with a 200-250 HP engine will offer the same acceleration as a 2000 lb car with a 100-125 HP engine. That's honestly pretty decent.
    The problem is historically Chrysler has saddled their larger 4 cylinder vehicles with trash transmissions and less than optimal gearing. A nice responsive transmission with low parasitic loss makes a huge difference on smaller engines.
  9. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,592
    3,976
    Well, it couldn't be any slower than the 4cyl I had in my TJ (120HP IIRC?), but then my TJ was much lighter too (around 3000lbs?). So I'm cautiously optimistic about the new 4cyl for Wrangler. I'd still probably opt for the larger 6 but you never know.
    xjgary likes this.
  10. dmcdonald
    dmcdonald Active Member
    Jun 19, 2012
    872
    916
    There is much more to the equation than weight. Aerodynamics of most 2000lb cars are far superior to those of the box on wheels Wrangler, let alone the increase in rolling resistance and parasitic drivetrain loss.
    Agree that a modern transmission such as the ZF 8spd will make a huge difference.
    As an owner of multiple 4cyl Wranglers, I will say that the level of performance and acceleration of those models would not be acceptable in today's market.
    UN4GTBL, Ruptured Duck and aldo90731 like this.
  11. aldo90731
    Jul 6, 2010
    6,007
    9,982
    And no 2,000 lb car has anything resembling 32" tires.
    It takes a lot more torque to turn 32" tires. Let alone the 33" tires that reportedly will appear on JL.
  12. XJMOPARMAN
    XJMOPARMAN Active Member
    Jun 27, 2013
    92
    102
    Asking for a friend... Could the 8 speed be tuned so it uses 2-8 under normal driving then use the low first gear when in low range on the transfer case?
  13. Erik Latranyi
    Aug 20, 2003
    11,054
    10,705
    The 2.0 T Hurricane should be good in the Wrangler with the 8-speed.
    It will not behave like a Pentastar 3.6
    It will not behave like an EcoDiesel 3.0
    But it should be adequate. The selling point will be fuel-economy and not much more.
    Bionicrooster and Ruptured Duck like this.
  14. MJAB
    Oct 4, 2013
    2,759
    3,054
    Technically yes, it could start in 2nd gear and even start in 1st vhen needed, for example starting uphill.
    It is what is done in Jeep Renegade/ Compass Trailhawk with 9 speed automatic, in normal conditions starts in 2nd gear.
    ScramFan likes this.
  15. WXman
    WXman Active Member
    Oct 28, 2014
    606
    551
    That's a shame, because a lot of guys were hoping this would be like the Mustang turbo-4, where you can simply load a tune to the car and outrun the V8 models. A "tuner Jeep", if you will. Would have been a load of fun and a really popular option. But it's starting to sound like that's not the case. :( This is a fuel economy sales item only.
  16. Ruptured Duck
    Ruptured Duck Active Member
    Jan 2, 2015
    879
    1,224
    Just know that tunes going that deep are getting harder and harder to crack. It will happen but not out of the gate.
  17. Mike V.
    Jan 24, 2008
    24,880
    18,751
    The auto magazines would absolutely destroy Chrysler for bringing out a vehicle that “underpowered”.
    JL is a brick with massive, heavy tires.
    Mike
    GasAxe likes this.
  18. Mike V.
    Jan 24, 2008
    24,880
    18,751
    I believe the 8 speed is already tuned that way when using “eco mode”.
    Mike
  19. MJAB
    Oct 4, 2013
    2,759
    3,054
    Many forget that the 2.0 has BSG system, it is a mild hybrid.
    This is from Continental, but almost all system from different suppliers work the same way.
    The electric motor allows powertrain engineers to have a wider election of turbochargers.
    Why? Because the electric motor allows to have additional torque (and power) at low rpm (an electric motor has maximum torque at 0 rpm).
    To add also that newer turbochargers with ball bearing have a lower response delay.
    12soldier likes this.
