Just installed mechanical oil gauge. what should oil pressure readings be?
Discussion in 'Pre-1994 trucks, commercial vehicles' started by upser145, Jun 11, 2017.
  1. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    Just put a new oil gauge in my 88 w150 with a 360 just wondering what hot and cold oil pressure should be at idle
  2. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    why is my oil pressure light still functioning with the sending unit unhooked also
  3. valiant67
    31,683
    10,965
    If your truck originally had an oil pressure gauge and oil light, they use separate sending units.
  4. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    oh i did not know this. I have haerd about 10 psi for every 1000 rpm when hot idling is this about right?
  5. Bob Lincoln
    Jul 10, 2002
    29,879
    3,258
    Depends on engine and condition of engine, temperature and viscosity of oil used, but often about 14-20 psi at idle, and then roughly 10 psi per 1000 RPM above the idle reading. Oil pressure lights typically come on around 4 psi, and as low as 7 psi hot at idle is considered the minimum safe.
    ImperialCrown likes this.
  6. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    Alright thanks
  7. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,557
    79
    I believe on the LA engines 8 psi puts the light out.
