AF: Keep killing alternators | Allpar Forums
Discussion in 'Vans' started by skloon, Jul 6, 2016.
  1. skloon
    skloon New Member
    Aug 23, 2011
    11
    78 b300 motorhome, every spring for the past 3 years I go out put my battery in the beast and start it and low and behold the alternator has died- why does it die when parked ??
    ImperialCrown Moderator
    21,011
    4,223
    We need more information. Is it discharging or making noise? In either case, the old alternator would likely need an autopsy for an answer.
    Quality control on reman alternators is variable. Most come with a 1 year warranty. Some stores may offer a better lifetime warranty.
    What part inside the alternator dies? Is it the same component failing every time? Brushes? Stator? Rotor? Bearings?
    Are there shorts in the battery or vehicle wiring that could damage the alternator? Is the alternator the correct size (amperage output) for the load involved?
  3. ka9yhd
    ka9yhd Well-Known Member
    Aug 17, 2013
    1,313
    271
    Take it to a rebuild shop and let them find out what died inside the alternator. Just replacing the alternator with another reman alternator will not tell you anything. You will never know if there is something causing the problem or was it a poor job of a rebuild of the alternator.
    ImperialCrown likes this.
  4. dana44
    Ad-Free Member
    Jun 17, 2002
    19,972
    1,608
    At the same time, if I have this right, you put the motorhome up for the winter and pull the battery cable so it doesn't go dead from sitting, are you sure the alternator is still functioning when she is put up for the winter? The charging system problem may be something else causing it to go bad, such as a voltage regulator or a converter (if you have one set up with it, being a motorhome), and the alternator is actually overheating/overcharging and then sitting during the winter an overheated/heat damaged part corrodes to the point of instant failure when electricity is put to it after sitting.
  5. skloon
    skloon New Member
    Aug 23, 2011
    11
    I have a 'lifetime' warranty on the alternator but I will take this one and get it checked- I pull both batteries and only put the starting battery in- the thing spins but doesn't put out a charge- I will probably change the voltage regulator too as it came with a couple of spares
  6. ImperialCrown
    21,011
    4,223
    Have them bench test the alternator for output. Does the ammeter in the instrument cluster work? The bulkhead (firewall) connectors on these vans had problems with poor connections getting hot and melting plastic.
    The ammeter/shunt is part of the charging circuit.
    Put a voltmeter across the battery terminals for some charging system diagnostics.
  7. skloon
    skloon New Member
    Aug 23, 2011
    11
    Had it tested not putting out anything at all-I am going to check the bulkhead, thanks for the diagram it makes more sense than the schematic
  8. A-Body
    A-Body New Member
    Jun 28, 2018
    18
    Alternators are tough on dodges. I changed one in 40 years, but I have installed brushes around 3 or 4 times(simple to do). The voltage regulator is another story. I always keep an extra one in the van, just in case. Have change that also around 3 or 4 times.
