LD Charger Sales Codes, Upfit, Colors
Discussion in 'Police, Taxis, Ambulances, etc' started by AHBGuru, Sep 21, 2015.
  1. AHBGuru
    AHBGuru Active Member
    Mar 22, 2015
    210
    89
    I thought to record all of this for posterity, since this information seems to get lost along the way pretty easily.
    (From the 2013 Chrysler Fleet LEV Catalog)
    Notes:
    - LD Charger dates to Sept of 2010 (2011 model year) through (at least) model year 2016
    - Some of the features/options listed were present on the 2012 cars.
    - Late 2014 added Large Brake package (BR9) and AWD as an option. The 18" rims and wheel covers are AWD specific.
    - 2015 - Car refreshed, Aluminum rims are NLA on Charger Pursuit
    - 2016 - Large 12.1 center screen available
    CHARGER PURSUIT FEATURES AND OPTIONS
    Police Group (AHB) Standard
    Severe Service Group (AHV) Standard
    MECHANICAL FEATURES
    Alternator — 220-amp (BAJ) • •
    Automatic Headlamps (LMG) • •
    AutoStick Automatic Transmission (DHD) • •
    Battery — 800-amp maintenance-free (BCF) • •
    Brake/Park Interlock (XSL) • •
    Brake Assist (BGE) • •
    Electrohydraulic Power Steering (XXK) • •
    Engines — 3.6L V6 24V VVT engine (ERB) •
    — 5.7L V8 Hemi VVT Engine with Fuel Saver Technology (EZH)
    Includes 215-mm rear axle (DPP), high-speed engine controller
    (NZ5), P225/60R18 BSW Performance tires (TWW) — Included
    with EZH without TWM Performance Exhaust (NEA)
    Engine Block Heater (NHK) — Included with Alaska destinations O O
    Engine Hour Meter (XAX) • •
    Engine Oil Cooler (NHA) • •
    Fuel Tank — 19.1-Gallon (NGA) • •
    Heavy-Duty Suspension (SDB) • •
    High-Speed Engine Controller (NZ5) • •
    Load-Leveling and Height Control (SER) • •
    Performance Steering (SBP) • •
    Primary Speedometer — 160-mph (JCC) • •
    Power Accessory Delay (JKY) • •
    Power Steering Cooler (NHF) • •
    Rear Axle Ratio — 2.65 (DLC) • •
    Rear Axle — 200-mm (DRD) •
    Rear Axle — 215-mm (DPP) •
    Severe-Duty Engine Cooling (XDK) • •
    Tip Start (XBN) • •
    Tires — P225/60R18 BSW Goodyear® Performance Tires (TWW)
    (M/H 27A) O •
    — P225/60R18 BSW Firestone® Performance Tires (TWM)
    (M/H 29A) • O
    — Compact Spare Tire (TBC) • •
    — Full-Size Spare Tire (TBW) O O
    — 18-inch Wheel Covers (W8A) (N/A with AEB) O O
    EXTERIOR FEATURES
    18- x 7.5-inch Steel Wheels (WEJ) • •
    Acoustic Front-Door Glass (GAP) • •
    Acoustic Windshield (GAK) • •
    Black Grille with Black Honeycomb Design (MFU) • •
    Black Headlamp Bezels (MFA) • •
    Black Left Spot Lamp (LNF) O O
    SELECTED FEATURES AND OPTIONS 3.6L Pentastar 5.7L HEMI
    Black Police Graphics Set (M2C) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Body-Color Door Handles (standard colors only) (MNK) • •
    Body-Color Exterior Mirrors (standard colors only) (LEP) • •
    Body-Color Lower Bodyside Cladding (standard colors only) (MRC) • •
    Bright Hub Caps (WMH) • •
    Can-Control Siren System (JJK) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Capless Fuel Filler (XJM) • •
    Cargo Compartment Dress-Up (CKM) • •
    Charger Badge (MT1) • •
    CHMSL Lamp (LPA) • •
    Dual Bright Exhaust Tips (NEL) • •
    Dual-Note Electric Horns (JJB) • •
    Dual Rear Exhaust (NER) • •
    Equipment Mounting Bracket (XFX) (N/A with AEB, AYM, AYH,
    AYF, or CUG) O O
    Front and Rear Solar-Control Glass (GBC) • •
    Front Corner LED Lamps (LNB) (included with AYF, AYM, and AYP;
    requires AYE, AYH, or AYN) O O
    Front License Plate Bracket • •
    Front Splash Guards (MEJ) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Grille Lights (MEK) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Halogen Headlamps (LMB) • •
    LED Spot Lamps (LNX) (requires LNF) O O
    Matching Right Spot Lamp (LNA) (requires LNF) O O
    Mirror Lights (late availability) (LNY) (requires AYE, AYF, AYH, AYM,
    AYN, or AYP) O O
    Overhead Full-Feature Light Bar (LN4) (requires AYE, AYF, AYH,
    Overhead Limited-Feature Light Bar (LN5) (requires AYE, AYF, AYH,
    AYM, AYN, or AYP ) O O
    Push Bumper (MBR) (included with AYH, AYM; M/H AYE, AYF, AYP, and AYN) O O
    Rear Corner LED Lamps (LNU) (included with AYF, AYM, AYP; M/H
    AYE, AYH, and AYN) O O
    Rear Deck Full-Width Light (LN3) (requires AYE, AYF, AYH, AYM,
    AYN, or AYP) O O
    Rear Deck Lights (LN2) (requires AYE, AYF, AYH, AYM, AYN, or AYP;
    N/A with LN3) O O
    Rear Splash Guards (MEG) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Side Lights (LNZ) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Spare Tire Relocation Bracket (TBH) (requires AYE, AYF, AYH, AYM,
    AYN, or AYP; M/H TBW) O O
    Trailer Hitch and Harness (XFN) (requires AYE, AYF, AYH, AYM, AYN, or AYP) O O
    Underhood Lamp (LDA) • •
    Variable-Intermittent Windshield Wipers (JHA) • •
    White Police Graphics Set (M2B) (requires AYE, AYF, AYH, AYM,
    AYN, or AYP) O O
    INTERIOR FEATURES
    Air Conditioning with Dual-Zone Temperature Control (HAD) • •
    Air Filtering (JMA) • •
    All-Weather Floor Mats (CLE) (requires M/H AYE, AYF, AYH, AYM,
    AYN, or AYP) (N/A with CKJ) O O
    Black Interior Accents (XSB) • •
    Black Vinyl Floor Covering (CKJ) • •
    Column-Mounted Automatic Shift Lever (CV8) • •
    Deactivate Rear Doors/Windows (CW6) O O
    Floor Carpet (CKD) (includes CLZ) O O
    Front and Rear Floor Mats (CLZ) (packaged with CKD) O O
    Front Dome Lamp (LCK) • •
    Front-Height Adjustable Shoulder Belts (CGD) • •
    Front Reading/Map Lamps (LBG) (included with AEB) O O
    Glove Box Lamp (LBC) • •
    Instrument Cluster with Tachometer (JAY) • •
    Integrated Window Antenna (RDL) • •
    Leather-Wrapped Steering Wheel (SCV) • •
    Non-Adjustable Pedals (XA8) • •
    Outside Temperature Display (LAH) • •
    Passenger Assist Handles (CSR) • •
    Power Mirrors with Manual Foldaway (GTF) • •
    Power Trunk Lid Release (JPC) • •
    Power Front Windows, One-Touch, Up and Down (JP3) • •
    Rearview Day/Night Mirror (GNA) • •
    Rear Window Defroster (GFA) • •
    Remote Fuel Door Release (JKD) • •
    Seats — Fixed Rear Seat (CFW) • •
    — Heavy-Duty Cloth Bucket and Rear Bench Seats (*C8) • •
    — Heavy-Duty Cloth Bucket Seats with Vinyl Rear (*X5) O O
    — Power Six-Way Driver’s Seat (JPS) • •
    Solar-Control Glass (GAM) • •
    Speed Control (NHM) • •
    Spot Lamp Wiring Prep (LNQ) • •
    Steering Column with Tilt/Limited Telescoping • •
    Sun Visors with Illuminated Vanity Mirrors (GNC) • •
    Tire Pressure Monitoring Display (XGM) • •
    Trunk Lamp (LDC) • •
    Visor Light (XGV) (requires AYE, AYF, AYH, AYM, AYN, or AYP)
    MEDIA/ELECTRONICS
    — 4.3-inch Touch-Screen Display (RFK) • •
    — 12-volt Center Console Power Outlet (JKW) • •
    — Audio Jack Input for Mobile Devices (RSU) • •
    — Customer-Defined Color Display Monitor (LAT) • •
    — Remote USB Port (RSX) • •
    — Six Speakers (RCG) • •
    — Uconnect® 4.3 Cd/Mp3 (RHA) (does not include Hands-Free
    Phone System) • •
    Keys — Entire Fleet Alike Key (FREQ 1) (GXF) (N/A with GXA, GXE, or GXG) O O
    — Entire Fleet Alike Key (FREQ 2) (GXA) (N/A with GXE, GXF, or GXG) O O
    — Entire Fleet Alike Key (FREQ 3) (GXE) (N/A with GXA, GXF, or GXG) O O
    — Entire Fleet Alike Key (FREQ 4) (GXG) (N/A with GXA, GXE, or GXF) O O
    — Four Additional Key Fobs (GQX) O O
    Consoles — Mini Floor Console (CUM) • •
    — Police Floor Console (CUG) (included with AYF, AYH, AYM,
    AYN; M/H AYE, and AYP) (N/A with XFX) O O
    — Replace Full Console with Mini Console (CM8) (requires AEB)
    SAFETY/SECURITY
    Advanced Multistage Front Air Bags(4) (CG3) • •
    All-Speed Traction Control (BNP) • •
    Child Seat Upper Tether Anchors (CF4) • •
    Daytime Running Headlamps, High Beam (LMK) • •
    Electronic Stability Control(3) (BNB) • •
    Front-Passenger Seat Belt Alert (LAX) • •
    Hill Start Assist (BNG) • •
    Hydraulic Assist Brake Booster (BPT) • •
    Inside Emergency Trunk Lid Release (JKK) • •
    Keyless Enter ’N Go (GX4) • •
    ParkSense® Rear Park Assist System(9) (late availability) O O
    Police ABS Four-Wheel Heavy-Duty Disc Brakes (BR8) • •
    Rain Brake Support (BHC) • •
    Reactive Head Restraints(5) (CBD) • •
    Ready Alert Braking (BHD) • •
    Rear Center Three-Point Seat Belt (CG6) • •
    Rear-Door Child Protection Locks (GXT) • •
    Remote Proximity Keyless Entry (GXD) • •
    Sentry Key® — Theft Deterrent System (GXX) • •
    Speed-Sensitive Power Locks (JPH) • •
    Supplemental Side-Curtain Front and Rear Air Bags(4) (CJ2) • •
    Supplemental Front-Seat Side Air Bags(4) (CJ1) • •
    Security Alarm (LSA) O O
    • = Standard O = Optional N/A = Not Available
    EXTERIOR COLORS
    No Cost:
    Billet Silver
    Bright White
    Copperhead Pearl
    Granite Crystal
    Ivory Tri Coat
    Jazz Blue
    Phantom Black
    Redline
    Extra Cost, Minimum 5 - Unit order
    Bright Silver
    Electric Blue
    Midnight Blue
    Michigan State Police Blue
    Tan
    White Gold
    MOPAR UPFIT PACKAGES
    Patrol Package #1 (AYE)
    • Front and Rear Wire Harness
    • Power Distribution Center
    • Siren Speaker and Bracket
    • Trunk Tray and Cooling Fan
    Patrol Package #1 (AYF)
    • Police Floor Console
    • Front Corner
    Led Lamps
    • Rear Corner
    Led Lamps
    Patrol Package #2 (AYH)
    • Push Bumper
    Patrol Package #3 (AYM)
    • Front Corner
    Led Lamps
    • Rear Corner
    Led Lamps
    • Push Bumper
    Slick Top Police Package #1 (AYN)
    Slick Top Police Package #2 (AYP)
    • Front Corner
    Led Lamps
    • Rear Corner
    Led Lamps
    MOPAR UPFIT INDIVIDUAL FEATURES
    Front Corner LED Lamps LNB
    Rear Corner LED Lamps LNU
    Grille Lights MEK
    Visor Light XGV
    Side Lights LNZ
    Rear Deck Lights LN2
    Full-Width Rear Deck Lights LN3
    Light Bar — Full Feature LN4
    Light Bar — Limited Feature LN5
    Can-Control Siren System JJK
    All-Weather Floor Mats CLE
    Push Bumper MBR
    Class II Hitch Receiver with Wiring Harness XFN
    Spare Tire Relocation Bracket TBH
    Center Console CUG
    Vinyl Graphics — (late availability) MAB/MAC
  2. JimVZ
    JimVZ New Member
    Nov 17, 2015
    9
    2
    If anyone is looking for a 2016 Charger Pursuit with about 250 miles, look no further than this forum under cars for sale.
  3. zeitgeist
    zeitgeist New Member
    Nov 2, 2016
    3
    I just picked up a 2013 Charger pursuit and would like to know more about the standard and optional features. Where are the above listed codes found on the car? Is there a way to get a window sticker like was originally on the car? Any help appreciated.
  4. AHBGuru
    Mar 22, 2015
    210
    89
    Sure, your dealer can provide everything with your VIN. They'll print out a "build sheet" with all of the equipment your car has.
    zeitgeist likes this.
  5. AHBGuru
    Mar 22, 2015
    210
    89
    Nice, but remember that Dodge lowered the bid price on these cars in mid-year. Because they aren't marketed or sold to retail customers, they sell at a bid price for lower than sticker.
