AF: LED bulbs? | Allpar Forums
LED bulbs?
Discussion in 'New Challenger, 300, Magnum, Charger' started by JFWONE, Oct 1, 2019.
  1. JFWONE
    JFWONE New Member
    Feb 8, 2019
    17
    3
    I have a '16 300 with regular lights/LED fogs.
    I'll admit I'm anal as hell about lighting, and I don't like the look. I'd like to convert the Hi/Low bulbs to LED. Is there such a conversion? A guy on youtube just replaced the bulb, but I wasn't able to find the bulbs he used.
    Also, if anyone has done this, how is the vision at night quality affected?
  2. Bob Lincoln
    Jul 10, 2002
    31,731
    4,974
    If you look around on some forums, some LED lights don't work - their loading is different from halogen, and the TIPM senses a fault and shuts them off within seconds. So be careful about what bulbs you buy, see what people on various forums have found to be successful.
    I just replaced the original bulbs in my 2011 200 when one failed, and I proactively replaced the bulbs in my wife's 2012 200, so the factory bulbs tend to last about 8 years, and we found them plenty bright enough.
  3. valiant67
    valiant67 ...
    36,176
    18,537
    When I had my 2013 Chrysler 300S the factory high beams were terrible (as in the light amount and pattern was almost unchanged over the low beams). I researched a lot of options and different bulb drop ins. I really was considering the factory xenon setup.
    However, as Bob mentions you'll have to search to find a setup that works with the car's factory electronics.
    The other problem is a headlight assembly designed for a halogen bulb may not properly disperse the light from another type of bulb so you may get worse than stock results or better than stock results depending on the bulb. Lots of people with LEDs go with gimmicky shades of whiteness or blueness. I don't think there's going to be any shortcut to reading lots of swap stories on line.
