AF: Looking for fuel tank vent valve | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by Artie K Car, Nov 26, 2017.
  1. Artie K Car
    Artie K Car New Member
    Nov 26, 2017
    13
    Hi All,
    I have an '88 Reliant and need to find a replacement for the fuel tank vent valve. I have searched ALL parts sources, and no one has it. I know that there's a part from Dorman BUT it only has one port on it, whereas the Reliant has an inlet & an outlet. If the part is available, even used, then I may be interested OR if anyone has used the single port type valve and was able to do something with the in & out fuel hoses.... Thanks in advance
  2. Best Answer:
    Post #8 by bamman, Nov 28, 2017
  3. ImperialCrown
    ImperialCrown Moderator
    21,100
    4,285
  4. Artie K Car
    Nov 26, 2017
    13
    The valve as shown in the service manual is the correct one. The alternate valve will not work + that PN is for the grommet only. I guess I will have to try another idea, which is to glue the broken piece back on. I am very surprised that no one has this valve !! It was used on many different vehicles for a 10 + year period. Thanks for trying "Mr Crown"
  5. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,959
    667
    Any pictures of your broken one??
    Thanks
    Randy
  6. bamman
    bamman Part Connoisseur
    Apr 22, 2003
    2,431
    28
    The two rollover valves perform the same function. The earlier two port valve had the second port to vent sudden excess pressure (but not gasoline) to the atmosphere. The later one port valve was engineered with a built in orifice to vent excess pressure back to the charcoal canister instead of the atmosphere. The later valve, part number J5360058 with grommet 52018823, has been reported to work in our applications.
  7. Artie K Car
    Nov 26, 2017
    13
    [​IMG]
    It looks similar to this one but there is a second tube that extends out the opposite side + it has a rubber grommet, not a metal cap on the end
  8. Artie K Car
    Nov 26, 2017
    13
    The later valve may work, BUT there is still what looks like a fuel line that goes to the vapor canister ( I will have to verify that when I can get out and look at the vehicle ) + you write that the valve works in "our" applications..........I presume that's the 3 vehicles you have listed ?? Being in California, I need to be sure that whatever I install will not violate the emissions testing
  9. bamman
    Apr 22, 2003
    2,431
    28
    Let me clarify. There are two rollover valves used in 86-95 Chrysler vehicles. The rollover valve used in 1986-1990 model year vehicles was part number 4279941. This valve featured two nipples on it. One nipple that vented to atmosphere and one nipple that connected to the vapor canister.
    The rollover valve used in 1991-1995 model year vehicles was part number 4495069. This was the “combination” pressure relief and rollover valve. The single nipple will connect to the vapor canister.
    Both valves perform the same function.
    The J5360058 valve is another combination valve reported to work perfectly in both the 4279941 and 4495069 applications.
    Will the J5360058 violate any California emission laws? I do not know for certain. If California drops the fuel tank and removes the valve to inspect the part number it may fail. If they pressurize the fuel tank, all three valves should perform in the exact same manner. A quick google search revealed that in some rollover valves with a vent, some people capped the vent and that failed the California smog test. Removing the cap allowed it to pass. That is the only thing I found when searching for rollover valves and California emission testing.
  10. Artie K Car
    Nov 26, 2017
    13
    Thanks bamman !! Sorry for the delay. I've been getting the other parts needed, and have put off the valve. Not sure what I will do next, but wanted to extend a TY to you, albeit it late
  11. 1999 White C5 Coupe
    1999 White C5 Coupe Well-Known Member
    Jul 11, 2006
    488
    339
    1990 Chrysler New Yorker Parts - (at https://chryslerdodgejeepfactoryparts.com/parts/1990/Chrysler/New%20Yorker/index.cfm?action=partDetail&section=FUEL%20SYSTEM&group=FUEL%20SYSTEM&subgroup=FUEL%20SYSTEM%20COMPONENTS&component=Rollover%20valve&partnumber=4279941&vehicleid=87060&siteid=218137 )
  12. Artie K Car
    Nov 26, 2017
    13
  13. ImperialCrown
    21,100
    4,285
    As a test, I put the part in my shopping cart and got to checkout with it, but admittedly did not go any further.
    The part certainly is discontinued by the factory, but I didn't know if this parts dealer was selling obsolete and NOS parts. Had you tried taking a purchase transaction all the way through to the end?
  14. Artie K Car
    Nov 26, 2017
    13
    No I have not because every one of the sites that shows the part all show it's discontinued. I'm going to try and use the old/broken valve and see what happens
