looses most of blower through dash vents after a long run 02 Dakota
Discussion in 'Dakota, 1998-2013 Durango and Aspen' started by Marty Eagan, Oct 10, 2017.
  1. Marty Eagan
    Marty Eagan Member
    May 29, 2015
    2
    02 Dakota,after an extended run,A/c all but stops coming out of dash vents.Still cold.Possable weak actuator?
    18,148
    2,620
    Possible evaporator icing up?
    Check your evap temperature probe reading. It should turn off the compressor to halt further cooling around 35°F (2°C).
    The actuator should hold the selected door position unless it is told to move somewhere else by the controller.
