micro vibration in steering wheel.
Discussion in 'Minivans · Pacifica' started by voiceofstl, May 22, 2017.
  1. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    975
    330
    On my 2016 with 10.000 miles caravan there seems to be a micro vibration coming through my steering wheel. I only noticed it on the highway after driveing 15 min. or so.
    You can't feel the wheel shake or anything like that but after awhile my hands feel like they have "fallen asleep"...its hard to describe.
    Has anyone else encountered this?
    18,347
    2,707
    A small steering wheel shake is sometimes called steering 'nibble'.
    Can you see any vibration at the rim of the wheel when you hold it by your fingertips for a moment? Does it seem speed dependent? Has it had or did it happen after a tire rotation?
    Hand and wrist fatigue can be a real problem on long drives with vibration from a hard steering wheel or handlebars.
  3. voiceofstl
    Jan 15, 2010
    975
    330
    I can only "feel" it at highway speeds. I can't see any vibration.
  4. Ray Green
    Ray Green Living in RV heaven. You think cars are bad!
    Aug 25, 2002
    1,530
    37
    Have the front tires balanced. A slightly irregular condition can telegraph through the steering. Tape a toothpick or coffee stirring stick to your steering wheel pointing straight up. Watch it while you're at highway speed and see if it quivers.
  5. Bernard Feltzer
    Bernard Feltzer Active Member
    Apr 12, 2006
    177
    1
    My 2005 T&C did that since new. At 16k miles the power steering hose from the ps pump sprung a pinhole leak. It was a high pressure line, replaced the hose with a whole new assembly. Power steering was nice and normal after that.
    Ray Green likes this.
  6. ohcdoug
    ohcdoug Active Member
    Mar 25, 2003
    303
    7
    I have had this on more than one car...its either unbalanced tires at the front or the tire plies have separation inside...had that more than I care to say.and that means new tires.
