Mitsubishi V6 timing belt
Discussion in 'Welcome to Allpar!' started by patrick horrocks, Oct 25, 2017.
  1. patrick horrocks
    Oct 25, 2017
    1
    Is the mitsubishi V6 an INTERFERENCE engine if the timing belt breaks?
  2. valiant67
    31,636
    10,867
    Assuming it’s the SOHC common in the 1990s cars, no it is not interference.
  3. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    882
    288
    The 3.0 doesn't get alot of love here. It does tend to leak alot of oil after 100k but as long as you change nthat belt and check your oil its a easy 200k engine.
  4. ImperialCrown
    18,220
    2,653
    Welcome to Allpar. The 3.0L SOHC/12-valve used in the domestics was non-interference. The 3.0L DOHC and 24-valve used in Stealth and DiamondStar products was interference.
    The Mitsubishi 2.5L V6 used in the JA/JX cars was also interference.
    Replace the water pump and idler/tensioner pulleys while you are in there.
