Mopar’s already geared up for 2018 Wrangler JL
Discussion in 'Mopar News' started by Dave Z, Oct 31, 2017.
  1. DarkSky
    DarkSky Moderator
    Jan 29, 2016
    1,839
    2,606
    Shh, no you can't. That's just... black mud splatters.
    suzq044 likes this.
  2. aldo90731
    Jul 6, 2010
    5,745
    9,222
    That’s very good news, indeed.
    Boy, first we find out SelecTrac is the real deal; now that Sahara can handle 35” tire right out of the box.
    Must be Christmas time...!
    dmcdonald and Zagnut27 like this.
  3. mopar22
    mopar22 Well-Known Member
    Sep 22, 2010
    1,182
    387
    Who is the maker for the transmissions, both 6 and 8 speed.
  4. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,612
    2,808
    850RE (ZF 8HP50) is made under ZF license by FCA at Kokomo Transmission Plant (Indiana, U.S.A.).
    It is used the standard gear ratio set
    4.714 3.143 2.106 1.667 1.285 1.000 0.839 0.667 3.300
    but there is an alternative gears set not used, at lest for now, in Jeep Wrangler JL.
    5.000 3.200 2.143 1.720 1.314 1.000 0.822 0.640 3.456
    ZF 8HP75, that will be used with 3.0 diesel engine, will be sourced from ???
    The 6 speed manual, that is a modified version of another transmission, could be AISIN, but don't know if true.
  5. aldo90731
    Jul 6, 2010
    5,745
    9,222
    See, if FCA did launches like this every year, there would be a lot less bickering going on.
    I know I would be more willing to put up with crummy customer service, and even my brother’s Renegade issues, if I got my candy.
  6. CherokeeVision
    Dec 9, 2004
    5,330
    1,952
    Has anyone seen anything that states that next years diesel will have the Dana 35?
  7. aldo90731
    Jul 6, 2010
    5,745
    9,222
    Here is today's JL Los Angeles press presentation:
    I love hearing "torque management" 4WD systems. No electronic gimmicks; no virtual systems. These are the real deal.
    #427 aldo90731, Nov 29, 2017
    UN4GTBL and Erik Latranyi like this.
  8. MJAB
    Oct 4, 2013
    2,612
    2,808
    Well also the ones in other models use clutch packs, so is hardware solution.
    The electronic part is for torque management.
    What in certain circunstances, with engines with lower torque, is the "brake lock differential" feature that have a negative effect (also in Wrangler).
  9. MJAB
    Oct 4, 2013
    2,612
    2,808
    The Dana 44 of Rubicons are described in FCA press kit, that, as FCA tradition are a little bit confusing and with some contradictions, as
    "... New heavy-duty Dana 44 front and rear axles standard on Rubicon models ..."
    Dana 44 heavy-duty solid front
    Dana 44 (220mm) heavy-duty solid rear
  10. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    9,505
    15,003
    @suzq044 & @DarkSky better start photoshopping JT with the abundance of JL pics
    UN4GTBL and DarkSky like this.
  11. redriderbob
    Feb 22, 2004
    9,505
    15,003
    The cover Wranglers at the LA Auto Show were Mopar equipt concepts...
    UN4GTBL and GasAxe like this.
  12. redriderbob
    Feb 22, 2004
    9,505
    15,003
  13. redriderbob
    Feb 22, 2004
    9,505
    15,003
    Lots of this Mopar goodies were hinted on the Trailcat Concept from Moab.
    UN4GTBL likes this.
  14. redriderbob
    Feb 22, 2004
    9,505
    15,003
    Jeep Display at LA Auto Show
    Shane Estabrooks and UN4GTBL like this.
  15. redriderbob
    Feb 22, 2004
    9,505
    15,003
  16. redriderbob
    Feb 22, 2004
    9,505
    15,003
  17. redriderbob
    Feb 22, 2004
    9,505
    15,003
    My Sky One Touch roof
    UN4GTBL likes this.
  18. suzq044
    suzq044 Resident Photoshop Nerd
    Apr 23, 2005
    7,037
    4,800
    Question: is the white one on the stand a retrofitted JK, or did they not have another set of JL tail lights for it, or are those going to be mopar aftermarket parts? Or do the 2 doors have a different tail light assembly? e.O
    Honestly, I think the latest renderings are pretty damn close, but I'll play with it..
  19. Stomper
    Stomper Well-Known Member
    Feb 10, 2011
    467
    97
    Bob S. once posted that management came down hard on him when he designed an aspect of the Ram BR suspension to make it easier to change for the aftermarket. He repeatedly pointed out that manufacturer's do not generally take into consideration what people do to their vehicles after purchase. The Wrangler is somewhat of an exception but cost will always be a consideration and money was saved by not equipping every Wrangler with a D44.
    ScramFan and aldo90731 like this.
  20. redriderbob
    Feb 22, 2004
    9,505
    15,003
    Its a JL... every on it is a Mopar accessory including the narrower fenders.
