Mopar’s already geared up for 2018 Wrangler JL
Discussion in 'Mopar News' started by Dave Z, Oct 31, 2017.
  1. wilbur
    wilbur Active Member
    Feb 19, 2014
    774
    648
    I was too busy looking at the scratches on the axle to notice that. good eye... :)
    Another thing they said and I think it was also mentioned on the forum is the raising of the fenders to allow 35's stock... I really like that as I am not the greatest fan of lift kits. Nothing wrong with a really good setup, but the cheap ones can be pretty scary.
    Wil
  2. Dr. Jeep
    Dr. Jeep Well-Known Member
    Mar 28, 2005
    200
    221
    You can get 35's on the JK as well with no lift (Mopar has a high clearance fender kit for the JK that does the same as these JL Rubicon fenders). However, I agree with you that this is set up a lot nicer on the JL. With a JL Rubicon you already have OEM wheels with the correct offset and backspacing for 35's, so you don't need to buy new wheels. The axle width on the JL is also properly setup for 35's, so you don't mess up the scrub radius like you do by putting 35"-compatible wheels on the JK. The JL has strengthened C's that seem like they won't be as susceptible to bending like they are with 35's on the JK's D30 and D44 (with really hard 4wheeling). The JL has upgraded thickness of the axle tubes on the D44's, again, not as big of a concern with bending with hard wheeling on 35's like the JK. Lastly, the JL Rubicon has upgraded brakes basically equivalent with the Big Brake Kit that you could get from Mopar. There are so many things that they thought of for 35's on the JL Rubicons, it really is a complete package for that tire size. They aren't kidding when they say 35's are package protected on the Rubicon.
    Agree also about preferring this style of fitting 35's over lift. While lift provides improved clearance elsewhere, it also increases frontal area by quite a bit. Fitting 35's with a fender modification and keeping the frontal area lower by not lifing the suspension also helps fuel economy (a bit).
    This all has to be figured in on the price of the JL Rubicon as honestly it will be quite a deal over the JK Rubicon, even with a price increase. You have to figure that for the JK to get to the same point with 35's, it needed:
    - brake upgrade kit (~$1000)
    - high clearance fenders (~$500 - $1000)
    - new wheels ($750 - $1300)
    - axle tube sleeve and C reinforcement ($300 + welding and assembly costs)
    ...and that doesn't include installation cost. And you still aren't on par with the axle width improvements and scrub radius of the JL Rubicon without replacing the front axle entirely. There's a minimum of $3500 improvements baked into the JL Rubicon just on those above items alone... and being package protected for 35's the JL is going to be covered under warranty on all of those components, whereas if you do that stuff to your JK... forget it...
    xjgary, wilbur, GasAxe and 2 others like this.
  3. wilbur
    Feb 19, 2014
    774
    648
    Thanks for taking the time to explain the differences between the Jk and JL rubicon’s.
    will 35’s fit on a sport or Sahara without modification?
    Wil
  4. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    9,521
    15,080
    [​IMG]
    [​IMG]
    JL makes JK look so cheap looking. One thing I am really happy about FCA US Product Design Office is they are putting a lot of detail into their designs. For the past decades, vehicles were slab sided and just lacking body lines and all the design focus was into headlight design. It feels like the PDO is getting back into the 90s swing of things were Chrysler's design was more of an art than anything.
    Mark Allen & Ryan Patrick Joyce and the rest of the team should be extremely happy with how beautiful JL turned out.
    #524 redriderbob, Dec 7, 2017
    xjgary, AlfaCuda, aldo90731 and 8 others like this.
  5. redriderbob
    Feb 22, 2004
    9,521
    15,080
    Our own Patrick Rall is at the first drive event... here are a few pictures from him...
    [​IMG]
    [​IMG]
    He's driving a new Hurricane errr eTorq Sahara model
    [​IMG]
    Jeep is going all out bring out the new models and vintage Willys, CJs and Wranglers.
  6. redriderbob
    Feb 22, 2004
    9,521
    15,080
  7. LordHobbit
    LordHobbit Active Member
    Nov 4, 2016
    103
    118
    I just realized the Jeep badge is gone from the front. Looks are iconic so it's not needed apparently ...
  8. DAGAR
    DAGAR Active Member
    Sep 21, 2014
    1,394
    1,986
    Yep, it's back on the side where it belongs ;)
    wilbur, UN4GTBL and GasAxe like this.
  9. zack_falcon
    zack_falcon Active Member
    Feb 15, 2015
    205
    152
  10. aldo90731
    Jul 6, 2010
    5,757
    9,283
    I really like those Sahara wheels. They look like gears, or bearings, or zipper cogs. All of which infer “traction”.
    GasAxe and dmcdonald like this.
  11. aldo90731
    Jul 6, 2010
    5,757
    9,283
    Am I seeing correctly that JL has “halos” around the headlights?
    If so, that’d be great, and reason to ditch those silly fender-mounted LEDs.
  12. redriderbob
    Feb 22, 2004
    9,521
    15,080
    Yes JL does.
    aldo90731 likes this.
  13. redriderbob
    Feb 22, 2004
    9,521
    15,080
    It is fixed.
  14. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,475
    3,731
    Next step...full steel roof as an option perhaps?
  15. Ruptured Duck
    Ruptured Duck Active Member
    Jan 2, 2015
    856
    1,182
    The power top can be removed but it's not recommend from what I was told. The standard freedom hard top can still be easily removed as before.
  16. Ruptured Duck
    Jan 2, 2015
    856
    1,182
    It's always been speculated but no official word. As a global expansion of the brand it make sense to me. Also the waist line styling que would greatly help to break up the body and look for a full steel design. Just my opinion with no back up info.
    Zagnut27 likes this.
  17. BobbiBigWheels
    BobbiBigWheels I'm likely at work...
    Jun 2, 2016
    2,555
    3,345
    One step closer to a "Lux" Wrangler!
  18. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,475
    3,731
    It would be nice...more livability over a regular Wrangler...perhaps more akin to the old XJ’s. It would be interesting to see anyways.
    MJAB likes this.
  19. redriderbob
    Feb 22, 2004
    9,521
    15,080
    Sky One is fixed on JL with six bolts from what I was told. Two front, four rear. You then have to unplug a harness, remove rear quarter windows and rear window as well to remove. Far more complicated than that of the Freedom Top and Soft Top. Also its one big piece, so have fun trying to lift it and store it somewhere. FCA US said its possible, but don't recommend doing so with the Sky One roof.
    Hope that makes sense.
  20. freshforged
    freshforged Well-Known Member
    Dec 4, 2003
    2,137
    1,346
    wagoneer
