My mom's 2012 Journey runs bad
Discussion in 'Dodge Journey' started by Tori G., May 9, 2015.
  1. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    My mom's 2012 Dodge Journey runs bad and does show a code,a PO302 misfire code.Did the simple checks and knew to do this.Did a compression test on this cylinder,It is a little low than spec.The plug looks good.It has 67,000 miles on it.My mom bought this new 3 years ago and she likes it.I know it still has a warranty,bought it new August of 2012.I told her take it back to the dealer,still under warranty.What can it be since the plug looks good?Checked for vacuum leaks too,none.
  2. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,145
    1,650
    Which engine? V6 or 4? Check Engine Light on? I agree if still under warranty take it to the dealer for diagnosis.
  3. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    the 3.6 V6 and with the check engine light on with the PO302 code which is a misfire.
  4. paullybob
    paullybob Well-Known Member
    Mar 22, 2006
    438
    48
    Coil pack perhaps but at 67k miles, I'd yank those plugs anyway and start fresh. Dealer trip wouldn't hurt either since the code is there and it has warranty still.
    Bob Lincoln likes this.
  5. ImperialCrown
    18,232
    2,660
    A misfire could be a spark, fuel or mechanical issue. You already know that cylinder compression is a little lower. A cylinder leakdown test will tell you where the compression is leaking out. It does sound mechanical.
    A leaking valve, valve seat or piston rings will generally show up more at idle and lower engine speeds. Valve leaks generally won't get better with a 'wet' test.
    I would leave the P0302 code in the computer and get the car over to your dealer.
    http://www.sequentialtaillights.com/dodge/SB_PDF/TSB_LC_0900214.pdf
  6. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    I did not clear the code.I talked to friend of mine that works at a Chrysler dealership,said the cylinder head might be bad with a burned up valve.He has seen this twice causing the misfire with the 3.6.
  7. floridaman2013
    floridaman2013 Active Member
    Oct 17, 2013
    1,113
    320
    I concur as this was one of the early models of that engine to be changed with the L/S cyl head re-design.
  8. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    It was checked out on Monday and going to be done under warranty.Has a bad cylinder head and both are getting replaced.Found the compression was borderline on one cylinder in the other head
    PCRMike likes this.
  9. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    My mom is happy now and runs good now.Installed the revised heads too
  10. ImperialCrown
    18,232
    2,660
    Glad to hear it is fixed.
  11. Tori G.
    Tori G. Member
    Apr 4, 2015
    81
    40
    They did find burned out valves in the old cylinder heads and I seen it.Were not repairable
