Natural product helps quiet the all-new Pacifica!
Discussion in 'Mopar News' started by redriderbob, Aug 11, 2017.
  1. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    10,544
    17,676
    A really neat article....
    [​IMG]
    The 2017 Chrysler Pacifica is quieter, naturally.
    Designers of the all-new minivan used a soy-based foam to keep noise from entering the passenger cabin of the Pacifica.
    The plant-based foam blocks unwanted noise from entering the vehicle cabin while also saving on the overall weight of the minivan. The soy foam has a lower density than conventional acoustic material and weighs less.
    Since it is lighter, the foam provides yet another weight savings to the Pacifica, which is nearly 250 pounds lighter than its predecessor.
    In addition to being lighter, the soy-based product offers some characteristics not found in petroleum-based products normally used in such materials. The soy foam has a lower viscosity and a longer shelf life than traditional acoustic materials.
    The new foam also allows greater logistical flexibility for the plant because its six-month shelf life is two times longer than that of commonly used foam.
    This new body sealer was developed and supplied by Dow Automotive Systems. In addition to being lighter, the lower density requires less foam to be used to achieve the desired performance, and it reduces costs.
    The soy foam was first used on vehicles at the Sterling Heights Assembly Plant, and most recently on the 2014 Jeep Cherokee. Crews were also able to adapt existing equipment to accommodate the injection process with the new foam.
    To learn more about the Pacifica, visit the minivan’s website.
    MINIVAN MONDAY: Natural product helps quiet the all-new Pacifica | FCA North America Corporate Blog (at http://blog.fcanorthamerica.com/2017/08/07/minivan-monday-natural-product-helps-quiet-the-all-new-pacifica/ )
  2. codypet
    codypet Well-Known Member
    Jun 30, 2005
    1,625
    402
    And if you ever get stranded in the desert with your Pacifica, you can eat the foam :D
    MPE426HEMI, Zagnut27 and geraldg like this.
  3. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,384
    15,049
    Not really new... ;) I vaguely remember when that was brought out, which is surprising.
    suzq044 likes this.
  4. codypet
    Jun 30, 2005
    1,625
    402
    IIRC the Avenger/Sebring had it.
    Erik Latranyi likes this.
  5. desavona
    desavona Active Member
    Nov 4, 2014
    227
    122
    Is this used on the bottom of the vehicle as a skid plate also?
  6. HWDan
    Feb 14, 2017
    49
    97
  7. cgseller@gmail.com
    cgseller@gmail.com Well-Known Member
    May 16, 2007
    131
    39
    It was used on the band joist on my home for sealing a few years ago. It is very green but not entirely new. It is good to see none the less. It should be listed on some spec sheets somewhere.
  8. Shane Estabrooks
    Dec 9, 2014
    543
    347
    Does it have a MSDS, would be cool to see that.
  9. CherokeeVision
    Dec 9, 2004
    5,407
    2,088
    Shane Estabrooks likes this.
