Need a picture.
Discussion in 'A Body: Duster, Valiant, Dart, etc' started by LarryK, Sep 3, 2017.
  1. LarryK
    LarryK New Member
    Dec 31, 2016
    10
    My Valiant has a piece of structure bolted to valance and riveted to frame. I believe it is bent by a parking curb, as oil pan was crushed behind frame, taking 2 hrs. to remove said dent. Luckily the pickup was not touched. I had to remove bolt to take off belts, it is so close to transmission lines it could have sawed thru them. Is this supposed to be straight? Cannot find in parts book. Picture would be great. Thanks in advance.
  2. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,593
    358
    This??
  3. LarryK
    LarryK New Member
    Dec 31, 2016
    10
    CudaPete: That's it. Nut and bolt hit so many times it looks like a rivet. The metal is smashed up against the frame. Now I will grind off the what's left of the nut and bolt and weld on new and straighten the reinforcement. Thanks a bunch.
    Larry
  4. LarryK
    LarryK New Member
    Dec 31, 2016
    10
    Ground off flattened nut, found threads, vise gripped out, pounded piece flat, fits right and have 2" or more room to damper. Thanks.
